Alright so my friend @Paul77 is having a weird issue and I’d like to help him get sorted:
He switched out his straight cut gears (64/23 - 2.78 ratio) and 6355 190kv TB motors to helical gears (75/27 - 2.77 ratio) and 6380 190kv TB motors and his top speed dropped from 36mph to 31mph. This seems like too much of a difference to be the 0.01 gear ratio change.
So what could it be?
motor kv not being exactly identical?
user error in programming values?
helicals and straights transferring force differently?
ghosts?
Just to ask more questions, @Paul77, you didn’t change wheel size or gain 50lbs during the change?
Your motor and battery settings are the same between the 2 setups?
I appreciate all your help through this and, for real thanks for the thread start to figure it out.
Same wheel size same user weight, and the 6355’s I was running at 85A and the 6380’s I tried 85A, 90A and 100A to see if I could get more out of them but they are just 5-6 miles and hour top end slower. All other settings set the same.
I switched gears & motors around, and no matter what set up…slower
have you measured you top speed independently, aka GPS? same road conditions? Have you measured the speed of the old setup independently with GPS? Maybe you had the wrong settings before, who knows.
Sounds like that top speed drop roughly equates to the difference between a 190kv and 170kv motor. So, based on that, I would most likely go with what everyone else is saying. Definitely ghosts.
I mean… It’s not that far from normal… Assuming the numbers we used / calced are correct. A ‘typical’ tolerance might be +/- 10% which puts a 190kv motor in the 170-210kv range… Given that i only used erpm to the nearest 1k and voltage as measured by vesc (which can be dodgy), our estimated kv could also be +/- call it 5%…which puts us pretty well within a normal tolerance
