Mbs trucks
Moon gear drives (44/10T)
Torque board motors (170KV)
Trampa 9 inch mud pluggers
Trampa vesc 6s
Etoxx Vesc Box <3 <3
12s high discharge (45c) 9000 mah lipos
From todayās quick test ride (I am recovering from surgery and boston is cold so nothing crazy)
Rides like a limo
Still carves like a champ
Weights a ton and my batteries hate me
VESC HW6 > 4. Its just smoother⦠no comparision. Still some weirdness with FW on the MKIII, gonna poke frank to make sure Iām not doing anything stupid.
Update:
Swapped to Torqueboard motors. If you are using the 9T motor spurs, torqueboard motors are great, 2 flatspots + Keyway which also acts as a flatspot is amazing
DaveG claims 12mile range also need new lipos⦠these arenāt going to 100% anymore
Are you planning on getting a Davega? Or do you not care about reading speed / battery? Assuming you commute in the city you probably should!
I really like the black build aesthetic you have Odd question, but what makes this build heavy? From looks I would imagine Trampa decks being lighter than a regular street deck, and youāve got lipos instead of li-ionsā¦
I do have a Davega, need to calibrate. Context this isnāt a brand new build, this is more of an upgrade. I went from MBS rockstar 2, beltdrive, Unity and a lighter vesc box to what it is now. the board gained ALOT of weight. MBS did a really good job weight wise with the wheels and tires. So perhaps weighting a TON is more of a relative term. Still lighter then my kaly
I havenāt done anything crazy with the board. Again I am recovering from surgery
For reference I am 75 kg.
Board gone up inclines around 20 degrees.
Have not floored the remote or gotten anywhere close to flooring the remote.
That being said,
Zero cogging.
Start is smooth.
Acceleration is smooth.
Nice, I am the same weight and planning on using 6384s 190kv with 9ā, escapes, 5:1 3DServisas drive gear & a 12s4p Molicel 21700, these should pump enough amps I hope, something like 140A peak delivery.
I am using a switch. Theres some funkiness with it that I am trying to work through with frank. It turns on and off but also roll to start⦠Was hoping it would just be one mode
