Best pneumatic tires?
Trampa ship from shenzhen now?
No, it’s in transit before get to Indonesia :wink:
Just saw this powerslide suv wheels, do their wheels can be used for esk8 :face_with_monocle:
image image
If you can get the tube to fit, pump it up.
Have used wrong size tubes for years in bikes. Plenty of 26” tubes in 29” tires over the years. Can’t put a bigger size in smaller diameter but otherwise doesn’t matter as much.
What pnumies are you guys using for high speed? Right now I’m on the TB 160’s top speed so far is 41. I typically do alot of carving around 30-35 mph and have a final speed goal of 50. Willing to buy different hubs as well if needed. I’ve enjoyed the TB tires but I’ve already worn off half the tread on my drive tires in 80 miles
Aren’t TB hubs plastic? I would start with changing to cnc hubs, makes a difference at high speed.
Do you run on 4WD? 50mph on 2WD seems like a stretch xD
I like MBS Roadies for everyday rides, T3s for bad roads and trails. I’m no expert but I feel the most locked at high speeds in the TB Nummies.
I’m 2wd at the moment but am willing to upgrade to 4wd if needed. I’ve got plenty of battery lol what CNC hubs would you recommend. I’ve looked at trampa Megastar hubs a bit. Just trying to figure out what will fit on the TB218’s with TB v6 motor mount
Iahh ok I love the feel of the TB Nummies just seems like there wearing fast but then again I don’t know how fast they should wear :joy: most my riding is pavement just not always the best quality of pavement lol
What’s the highest wheel pulley to tire diameter ratio people have done?
like, 72T on metro 155s?
Any issues with that?
That would work. You’ll just need the 608 bearing adapters for 8mm axle.
Thanks! I will probably end up getting the offset ones. I like that wide stance :slight_smile:
Or get @3DServisas geardrives for an even wider stance :stuck_out_tongue_winking_eye:
You won’t be able to go back to cast hangers and plastic wheels lol
Damn!! :heart_eyes::heart_eyes: You guys are gonna make me spend alot more money :joy::joy:
What tires are those?
Metroboard 155mm.
By far the best tire I ever tried. But they are pretty rough on wh/mile.
I might have to try a set. Wh/mi dosent bother me. My board has more range than my legs do :joy::joy: it’s 12s8p 40t
