i’m not interested in the hub, i’m asking if It’s a good tire coz the price is interesting
This is my combo
This is my combo
Hmmm interesting. Gotta wonder what determined the tread pattern on your tires? Did you guys test multiple types?
If you plan to make new tire,160mm with offroad profile .
Do 9" tires take 200x50mm or 250x50mm tubes?
MBS uses 250x50 tubes
Crad, k.
Problem?
Yep wrong size sent.
Oh damn that blows
I wonder if I can just pump these up in there to make it work in the meantime.
I think you run a risk of just blowing out the tube
Nice! Where did you get this info from? My tubes weren’t marked and their site just labels them as 2.50 x 4 which is diameter. I’ve between trying to figure this out for certain.
I mean they have 8" tubes and 9" tubes…and the wheels are the same width, so I am making an educated guess that they use 9x2 tubes
I was just discussing in another thread. The fivestar hub is the only mbs hub that can hold the 9" tire. It’s got a wider outer lip (42.7mm) that the bigger tire beads on.
I’m gonna go blow up some raw 8 and 9" tubes and see
8" is 45mm wide.
9" is 50mm wide.
I think they’re 250 x 50 as well, not 250 x 75.
They both look goofy when pumped a bit without tire.
Why do your tube look like it has a hernia
Fill yours up without the tire and it’ll do the same quickly. The tire wall holds the tube in shape way more than I thought. Makes me clean the inside of my tires to make sure there’s no debris.
Update: MBS is badass, replacements already on the way. Small mixup aparantly
