Any concern with 12" wheel bite?
Our deck/trucks are designed to be safe until 10", but if we tighten the trucks a little, it should be fine.
On a drop through deck with flipped trucks.
The hub and pulleys are always the problem.
…amazing thing is those trucks bushing placement looks similar to NoSno
For reference: 90mm china, Fatboy 125mm gummies, 6’ shooters and FatBoy with 7’’ evolve. In my opinion, the last configuration is by far the best of all. The hub and the wheel are sooo balanced, they run really smooth.
thank you so much for sharing, i’ve been waiting to hear from someone who has rolled both the fatboy and six-shooter hubs.
Definitely going to order some metroboards 155s for those fatboys. Wide hubs make every tire look great though
Btw those evolve hubs are not compatible with my gear drive. Ive got that confirmed now
pls make compatible
this a diy forum bruh its just some sheet metal and a tap & die for folks like us right
(obviously beyond my skills, but not beyond most)
Screws are just a die and a Dremel… Show me the last screw you made for esk8…
i’ll also need a blow torch and a bucket of oil, and an oven to heat treat it for use
I dont have exact measurements. I just know they wont work atm
Why would you spend $500 on a drive but not spend the additional $100 for the hubs they are meant to run on?
Anyone have the width for the metroboard 155 AT tires? More specifically can you put them on 3ds 3.75 hubs and have clearance between the wheel and the drive.
Thanks.
Ohh I’ll answer it.
EDIT: yes you can
Have you tried fitting the TB tires to the Evolve hubs?
no 5chars
What’s the biggest size tires you can fit on bergmeister hubs?
