Hand knurling tool arrived.
No more noise in front trucks😍
Is that so the bearing inner race is tight on the axle?
Misumi I found the best prices for good Japanese bearings. I’ve been looking for a bearing quality guide. You can pay up to 20x as much for the same bearing. I’m sure to a good extent you get what you pay for but still wish there was someone doing comparisons somewhere. Other than a hardness test how would they test roundness? I’ve seen people do informal testing on a lathe but never roundness testing. Bet there’s a cool trick to see how round something is.
What bearings do you use John?
In my opinion 2RS bearings with heavy grease are the best. They have high rolling resistance but who cares. I am not the one pushing the board. Wh/km also doesn’t seem to be affected too much.
whoa - is that where all the whirring / creaking noises come from in my silent push boards? For the longest time, I could not put a finger to it and it’s been bothering all my skate seshs. Thanks for the tip!
I ride dry - no lubricants - is this a crime?
You just have to change bearings often and will also rust and seize easily if you ride in rain or wet roads often.
Just want to add some feedback on a bearing experience. New build with Heady shake bearings. They have not worked out well after less than 80 miles. Two let loose while still in the hub. Two more are garbage and won’t spin. The other four(from the front) still spin but are awfully noisy. Nothing like the race reds I just received. I’m a big boy and will probably be hard on bearings, but that was awfully quick. I ordered the race reds with integrated spacers, so I’ll report back any feedback.
Moving forward, I’ll likely order stock of generic and just swap them regular. The reds were ordered due to what could be here fastest.
Here is what was left in the hub. This and a ton of black debris.
Sent pics of the bearing failure to Zealous a little over a month or somethin ago. They wanted the failed bearing and said they’d send a little over a pack-o-new bear rings for it.
I sent it in, neva herd bach
I got honeydik’d
They did mention something about wanting to design an esk8-centric bearing tho
Not sure where else to put this but just here so it’s searchable
9.525mm by 22mm bearings are just R6 bearings. (Inches instead of mm). You’ll find more options from cheapos to ceramics under R6-zz for metal r6-2rs for rubber sidewalls
Just like these on Amazon for 9$ instead. 9.525 mm is harder to find options for.
Keywords: 9.5 9.525 12 mm mbs bearings ultimate truck matrix ii 2 two
Just regular industrial bearings with 2RS works great. ABEC 3 is enough.
If those are si3n4 that is silicone nitride and a lot better than full ceramic.
If u call locateballbearings.com they have them at that price. He’s trying to get rid of them and says selling them for his cost. He was hoping id take them all
What’s the ID of them?
https://www.amazon.com/Oust-Skateboard-Skate-Bearings-Types/dp/B07NH7V5RR?th=1&psc=1
MOC 9s are unequivocally the best skate bearings on the market. Period. 7s are also good though
They’re 608 standard skate bearings.
@kevingraehl did the knurling yielded a larger OD of the axles? I happen to have noise comming from my front truck as well.
Yes, worked perfectly… Let me find the video
If you pay for shipping both ways you can use my 70 dollar hand tool
8.30 for a priority box. @kevingraehl Venmo and I’ll ship today
I would rather buy one actually, I live in canada so shipping is out of the equation
Where did you buy it?
