Weipu SF12 or SF8 has seen some use recently
Offtopic, given your name i assume youâre in germany?
Yes, polarity was correct. I was using a 5.5x2.5 dc jack and had positive on the inside prong and negative on the outside casing. Thinking of changing that too with a new one. But as @glyphiks said I will not use a fuse.
The worst thing is that I canât charge (and therefore ride) until I receive my new chargerâŚ!
Any suggestions for round and short charge ports with a cap? Because I donât have unlimited space (depth-wise).
whatâs ur hole size?
Diameter 16mm but Iâm ok with up to 20mm I think. Depth cannot be more than 18mm because of the baseplate.
GX16-2P should fit right in, the port only need 13.1mm of depth
Example of a 3P version, but they are all the same
This thread is an absolute monster but for the most up to date battery building practices you can bring any questions here:
Oof, i canât recommend gx as a charge port due to the male pins. Weipu SF12 is my reco for charge ports
there are inverted version of the gx connectorâŚiirc
How much power is required to easily wheelie up the front end from a stop?
@Tony_Stark will be able to answer that ![]()
Whereâd you get that printed insert? And is that a switchblade?
I still donât know how people are making their boards do wheelies and burn outs. so if anyone knows the answer add that too please
Yes
I think that might be a remix of mine actually ![]()
A lot of motor amps and a front binding ![]()
Mine didnât start wheelieng till I got to 165 motor amps on 12S in BLDC mode (FOC seems to feel slower for the same amps in my experience)
Iâve gotten wheelies at 12s 60A per motor, but itâs geared for torque and Iâm light
No, itâs a hummie.
Depends if you have a tail, and also depends where your center of weight is relative to the back wheels, and also depends if you have a front binding.
A board with a [functional] tail will wheelie with no power and no bindings.
A board with no binding and the back wheels extended 50cm behind the foot platform probably wonât ever have enough traction or power to wheelie.
