Your whole body locks up muscles to brace for impact and it ends up feeling like you did a solid ab workout the next day.
If it’s not feeling better (on the mend) by 2 days, get checked for hernia. Seems like your pressure test indicates no hernia but still worth mentioning.
Thankfully it is already feeling better today to the point where I can eat. There is some soreness where my belt sits that wasn’t there yesterday but no visible redness or bruising. So there might have been some internal bleeding but if it did happen it wasn’t severe and stopped on its own.
Also could have been not keeping a boiled egg at the proper temp or taking a prescription pain killer on an empty stomach
I think this partially explains why I don’t poop the morning/day after a crash or a long session hitting booters on the snowboard.
Im regular AF, first sip of morning coffee and off to the john.
I may ask DR Drew about it
Ive been too freakin busy to get back to fixing it x.x
Probably tomorrow.
Im reeeeally hoping its anything but the esc. I have backup motors i can use, but i sold one xenith and immediately popped the other.
Anyone know where I can get a replacement for a VX2 battery without waiting for it to come from China? I haven’t had to replace a lipo before and I’m not sure what some good sources to get them from are. I wasn’t able to find one on Ebay either
If you can get your hands on some disposable vapes they all have 3.7v LiPo 1s pouches in them ranging from 400mAh to the highest I’ve seen being 2800mAh
bigclive on YouTube has a couple vids about it. I’ve been harvesting them for a couple years now.
I’m a soldering newb and with my 90W Amazon find solder iron I can’t tin the 10AWG wire. Wire doesn’t get hot enough for the solder to melt onto it. I don’t think I have solder with lead though, must be unleaded, I bought it in EU.
Might I be able to tin and solder the 10AWG wire with this gas powered iron? Dremel VersaTip (2000-6)
So long as you match the voltage of the old battery and it fits in the remote you’re good to go. You can get a new battery with a larger current listed and it will be safe to use. You can also get one with less current capacity but you’ll need to charge it more often.
I bought a replacement cell for an ESC remote and ended up getting a higher capacity battery that was larger than the original because it was cheapest and I had extra space to fit it in the remote shell.
I still maintain something else must have happened while you were swapping them or something. Nothing else really makes sense. I guess you can mess up by putting positive or ground on the wiper and then shorting them when you turn the pot all the way one way, but it seemed like you hadn’t done that.
