I would argue DIY esk8 is dead, premade china boards ar thriving. Also, blame the unreliable remotes for some known people to switching to unfancy no UI remote.
Hey guys,
Bought a custom kaly board board last year. It was running good until I threw it in a trunk. Now it doesnât have enough torque to get me moving while on it. The board will still go with nobody on it and will still hit close to top speed when lifting up the board. For whatever reason it goes a little bit better in reverse.
Is this likely a loose connection?
Also, with the bolts being so close to the trucks and motors, I recall it being a bitch and a half to tighten them up. Any suggestions on a tool for a tight spot?
TIA
Did you have smart reverse on? Sounds like the board is in reverse and youâre going forward with the smart reverse feature
I donât believe so, I have a Hoyt puck and restored default settings on my Vesc. That did not fix it. Thatâs as far as I got. Went to esk8con and said Iâm done looking at it (after a couple months here) lol
Eta: when I say itâll go with me on it in reverse, I mean less than 5mph which is a drastic drop
Did you change modes on the puck by accident? The lowest mode gives barely any throttle signal, so depending on the board, it will either be really slow or possibly not really move you at all. I thought I broke my board for about a day because Iâd never touched the mode button on purpose, and somehow ended up in the low mode. Reverse works fine because the modes only affect forward so you can still brake well. It sounds exactly like that to me.
Anything else I should try before just pulling the trigger on a vx4? I got another vx2 receiver from a guy on the forum after I broke the other one, I wired and soldered the wires tx and rx, based on the tenkas and receiver diagram to line up correctly, it has not paired, maybe there was not enough wire for the connection to go though on either of the tx or rx wires? Or more likely, itâs a vx2 receiver for a different modelâŚ? Is there a way to update firmware?
RIP
Youâre gonna need somebody reasonably well versed in vesc shenanigans to set up your board again
Where are you located?
Vegas, I restored them to the settings where it was working fine
In general, is that a no no?
As in you restored a backup of known good settings? That is usually a good thing.
Yes, that being said, I donât really know what Iâm looking at on my Vesc to know whatâs happening
Please get a new receiver and or remote and new wiring loom. No amount of money is worth risking riding a board with such shoddy connections all around that can lead to unexpected cutouts and accidents.
âbuy new stuff, practicing your repair skills is too riskyâ
You sound like apple lmao
How do I wheelie/manual on a mountainboard?
- Power
- Skill
bindings⌠lean back. balance.
use brakes/thrust to help like a moto.
practice practice practice.
practice more.
enjoy the practice⌠because youâll need to practice more. ![]()
So⌠Program the IMU? ![]()
18s and over 7kw per motor so⌠Not a power issue.
Clearly a skill issue haha
Doing a wheelie doesnât take much skill at all. Itâs the controlling it part that is hard. ![]()
Wow I am in fact a newb⌠that fixed it lol thank you
happens to everyone. thatâs how we recognize it.
