It still says regular for me on the little profile window too
Same spot it shows up on yours too.
I might just have broken the site a bit. I tend to accidentally do that more and more as I continue to refuse to upgrade my windows ![]()
Thats just showing the badge, not the trust level
Youâll lose your regular trust level if you donât maintain a quota
I just realized that it looks different when I view my own profile
so the trust level tag isnât there when I look at it.
Make sure to hit expand when viewing your profile, it should show it then.
I ended up figuring that out but somehow didnât figure out that I need to hit reply after typing my reply ![]()
PHASE CABLE SWAP / MOTOR DETECTION
If I swap two phase cables for better cable management, do I need to redo the whole FOC detection process?
Motors are now attached to gear drives, with dried loctite and Iâd prefer to avoidâŚ
There is no sensor on this motor.
@DavidC No problem. And no need to change anything in motor detection parameters, IF SENSORS ARE NOT INVOLVED.
You may have to change motor direction anyway.
@DavidC Thank you very much!
Hi guys I have a Lacroix Jaws 2.0 with the Stormcore 60d+, I messed up my settings in Vesc app a bit now my board only brakes very lightly until Iâm almost at a stop then applies the brakes properly when almost stopped so it takes me a long distance to slow down from speed, can someone please let me know what I need to adjust in the app to have the brakes back to normal?
Thanks everyone ![]()
up the negative value (more toward negative) to higher for motor current, start with something like -60, if still too weak for ur liking, go up to -70, then -80âŚetc
Thank you I will try this in the morning
Not really a beginner question, but @Skyart when would be the best time to order a motor from you? turns out that when I told someone I needed two motors that they still only bought one
they also bought the wrong KV option but
I was fine either way and kind of expected that mix up to happen
I donât really need them but just wanted to upgrade so waiting isnât an issue so I figured Iâd ask to see when would work best for you
There is currnetly a killer sale on 6485 size motors, discount is applied once they are in cart. The sale is part of a preorder and the motors will ship likely end of next week, or early following week. We already have tracking for them but i think it will be slow shipping progress over the holidays.
If you are buying the smaller 6355, these are in stock and can ship next day after purchase.
I missed out on the sale for the 6355 motors sadly
If I wanted to run 6485 Iâd only be able to fit one motor with the trucks I have and prefer. i do have wider trucks but I donât like them
I was asking to know what would be easier on you but if that isnât an issue I can just order them now
You did not! I forgot about this, use discount code â6355â at checkout for 20% off these
I think at some point I must have forgot it needed a code to be on sale, so thank you for reminding me
This will give me a chance to battle harden the ones I have and use those on the 2nd board I have neglected for half a year.
edit: I just ordered them now. pls pretend my given name doesnât exist. I havenât changed it purely because I have never come up with something better to use. Which is why I donât use it online
I always liked the name Jehosephus
If I do change my name it needs to be one I can spell
and also one that doesnât sound like I stole it from the bible
