Im running 10s3p p42a with 80a bms, 2x4.12 FS 50A esc, 6354 190kv FS motors, 18/36t pulleys. Essentially, the ideal settings from my understanding for my set up would be motors current max set at 50A and battery at 40A, but I am getting power losses when reaching the limits, as I tried describing above.Belts are not slipping, nothing is overheating, it is just weird. It would appear only at higher levels on the remote throttle, aka if I go above 75% on it. The issue became obvious when i switched my motors. It was present with my old motors, but only when i initiated a full brake and i never full brake so it didn’t bother me. After I switched to the current motors (higher KV) my understanding is that the previously present issue got exaggerated as the new motors being higher KV, need more power to produce the needed torque to push me.
Here I was referencing the BMS by “it”. I do not know what happens if I set it at 50A battery current max in the VESC.
a ) Will the BMS go over that 80A cont and provide the requested amps for some moments if the VESC requests that power during acceleration/braking
b) Will the BMS cut the power provisioning from the battery for safety and then provide it again once the requested power is below 80a?
c) If the VESC requests more than 80A, will the BMS still provide electricity, but just capped at 80A?
I will test again today and come back with what Info i get but it definitely doesn’t make sense to be going 46km/h when the projected loaded speed with my set up should reach 58km/h. And this power cutting is prety scary. I will probably record an RT log of a ride just to have it as data and can show what is happening.
The BMS doesn’t shut off power unless you hit 160+/-20A for a few hundred milliseconds, or 250+/-30A for a few tens of milliseconds. Google the datasheet for more info. The only thing determining current is the VESC.
Those ESCs (and the “upgraded” 4.20) are not 50A capable, that’s flipsky marketing nonsense. The received wisdom is 25A battery max, you can largely do what you want with motor current
The 4.12s have this as a known issue that needs a hardware mod. This from flipsky
Yeahhhh sorry I didn’t ask your specific ESC sooner, would have saved you some time but I got sucked in to what looked like an obvious problem of the current settings. The current stuff is IMO also still relevant but for future reference, giving as much detail as possible about what gear you’re using, what firmware, settings, etc you’re using will help. And searching for what you think is the problem like throttle + cutouts or motor + cutouts
I did search and look into it prior to posting, but I couldn’t find the exact thing that I am experiencing. I re-set up my motors using the motor setup wizard and it seems to be acting a bit better now, but couldn’t test it. I just changed the settings 100m from home and it seemed quite a bit better but still. Had to set up the motors with the belts attached though, not sure how much of a problem that is. I am not even sure if the thing you sent is the same thing, might be, not much details are provided regarding the nature of the issue.
Eeh, after the motor re-configuration, i lowered the battery current max to 38 i think and bumped the motor current max to 50. Currently, it seems like it is as smooth as butter. During initial acceleration the motors don’t even make a sound, they are like hub motors (which feels good, the previous generic ones i had would buzz even at 5km/h). I had the throttle to 100% for a few moments and it did feel like it was speeding up so it might actually be hitting 50km/h, but it needs further testing, I was without a helmet and with gym shorts so i didn’t feel like testing limits. Seems to work fine for now though, which is great, but also weird.
Ayyyyy great! I’d encourage you to lower the battery current even more, 25A seems to be the most you can safely get away with on those things. You may not even notice the difference. I had one of those in my first ESK8 and it blew up within a week so I have a vendetta against them
Eeh, if it dies I die with it. Sounds like a win to me. I’ve had it for a year now and I do ride my board a fair bit, not every day but i’ve often used it for 20km commutes. I like to believe that i’ve pushed my vescs enough and they seem to be going strong still (knocks on wood). I even remember running motor current maxes at 60A each and 50A battery cont for a while, before I fully understood what I was doing, thankfully it was in a tinkering period so at some point I was like “wait, no, dont do this”. I guess i might just be lucky with my batch. If they die and i somehow survive, it would be an opportunity to upgrade soo
If memory serves correctly the 60d+ are based off of 4.xx hardware, so the max ERPM you can achieve (or stay below) is 60 or 65k? I keep mine around 50k to be safe.
Thanks, did look at that, just looked a little weird. I’ll give it a go.
Is there enough clearance below the motors would you say? Can’t move it higher at the moment as it will hit the pivot part of the mount but moving the hangers closer to the wheels may give room to raise them if needed
