yeah thatâs what I was reading, Iâm still reading as I donât know how they got to have the temp sensor right
hmmm ? now Iâm curious
disconnect the motor completely, donât do it while its connected to the ecs
Touch 2 of the 3 phases together, then turn the motor by hand. With that you can count each magnet as it will âclickâ into place for each one.
Fully disconnect the Motor first
really ? I was dead sure shorting to phase only brakes it
Doesnât do any harm as long as it is fully disconnected and doesnât receive power
yeah I know, was just saying I never thought about it as a mean of counting poles, empiric knowledge was that it just prevent the motor from rotating ^^
I ask question in the noob thread but I still have a good few builds at my active xD
edit : I meant brake not break (itâs late here, my brains doesnât had enough sleep to proced decent english)
it causes braking, but only shorting two wires rather than all three causes choppy, discontinuous braking, and each âhumpâ or peak of braking force is one magnet pair. Therefore you can count the number of pole pairs by shorting two phase wires and rotating the motor.
Still gives me a good 5km/h difference between speed and gps speed
Iâll try counting them later today
Wheel size also plays a role in estimating speed. Sometimes a 90mm wheel is actually 92mm or something
Sometimes I wonder if measuring axle center height off ground is worth doing or if the difference is negligible. Probably on polyurethane itâs almost certainly negligible.
So 26 poles give me arround 2km/h average more than the gps, and is pretty similar in deceleration, Iâll try with 28 next ride
Edit : I tried the two wire short and counting the clicks, counted 166 for a full cicle ^^" no idea what to do with this
The og unity app measured a 12.7 factor for erpm to rpm, can I calculated the number of poles based on this ?
Well, I had stormcore issues, and they went from bad to worse. The stormcore doesnât turn on. Not with the button, not by shorting the BTN/ MOM pins and not even a different vesc button.
If anyone has any idea what I can do then Iâd appreciate the advice. Thanks.
You can try the troubleshooting steps here to see whatâs going on
There are a few things you can check continuity on a 3.3v pin to ground continuity on a 5v pin to ground continuity on that 2 pin V+/GND. Thatâs after the anti-spark system so itâs useful for checking shorts on the power stage Hold the power button and feel if precharge resistors (the three big resistors marked â1000â) are getting hot. Recommended to use a CC/CV power supply to watch amps, and limit power into the ESC. If any of those are short, it helps narrow down what failed.
So the manual is a bit unclear on what to do with the extra, and completely separate bat+ lead on the vx4 remote.
Why I am confused is because the PPM connections on my VESC is already supplying the receiver with the needed 5v power and the manual claims that using PPM doesnât allow the remote to display data. So I donât know why it would then want/use the voltage directly from my battery. Although the english in the manual isnât the best so I could be misunderstanding what they mean by ppm having âno data displayâ
Unrelated to my build, but since the remoteâs receiver includes extra pins for a second transmit and receive pinout then does that mean you could use it to control two separate controllers?
Batt+ will show you battery level when connected to your pack positive. It uses the ground pin in the UART port as the 0V reference.
Itâs not using Batt+ for power, itâs just checking the voltage. (Like your DMM)
They mean if you plug in to only PWM pins then you lose telemetry to the display as there will be no battery level sense and no Tx/Rx to send data.
If you want to use PWM and Bat+ but not the rest of the UART you wonât get any info on the display besides battery level, the rest of the display info is calculated on the remote using your throttle amount and input ratios.
The diagram doesnât show it being used at all for UART mode though.Which I had assumed meant that the VESC was just sending that data on the transmit pin. (I may also just be getting confused since my VESC has a separate area for PPM control and UART control so I might be misunderstanding what you mean by UART port )
Also my VESC does not have a bat+ pin on any of these pins (IDK what name to use for them)
There is a completely desperate pin for bat+ and bat- but that was was intended to be used for a separate display. Which I can use if needed but I just donât want to mess up the receiver by plugging into it if it isnât meant to be used for UART mode.
