All balancing done with that BMS is passive (using resistors to bleed charge).
What do you mean by “charge balance”?
LLT BMS has a setting to turn on “charge balance”
While turned on the BMS only balances while charging.
When turned off the BMS only balances when not charging.
Okay, but that’s not an opposite setting to “passive balance” since the LLT can only passive balance. Unless LLT has screwed up and is using that incorrectly as a term.
Do you mean balance when not charging? When the pack is at rest?
And you’re wondering what the advantages/disadvantages of each method are…balance when charging vs balance at rest?
Some BMS might allow balancing always (charge and at rest) and some only during charge and maybe even only at rest. All subject to voltage thresholds, of course.
Your BMS allows only balance during charging or only balance when not charging? Never “always balance”?
Yes, which one should I set it to? Or should I turn on charge balancing every time I charge it and turn it off when I unplug?
Unfortunately, it depends.
Needing to go through the trouble of turning off balancing every time would make me change my BMS instantly. Don’t accept anything that requires you to do stuff like that every time you charge. :slightly_smiling_face:
For fast charging setups, with a BMS that sets a high current level to stop charging at a high current level (typically 1/10th the bulk charge rate), it can be handy to balance when not charging since there is very little time to balance during charge. This is only needed for packs that…well…need it. A well-behaving pack might not need this.
Otherwise, balancing when charging only can help prevent a little extra discharging of the cells, keeping the pack voltage higher. But it does this at the expense of not balancing for as long. This might or might not be an issue for your pack.
Bottom line…you will need to test the different settings to see which is best for your setup and the way you charge. If you don’t want to deal with that then set it to only balance when charging and just accept how the pack balances over time.
What’s best option for spacers on front wheel axles? Are either of these ok? 2 spacers is too much and one is not enough. They are bn220’s
Stacking 6 billion washers to the exact distance u need
300 meters
Ideally you measure the exact gap and order or make a spacer the exact right size.
Or you stack 6 billion washers.
Thanks, I’ll look into that. Looks like 17mm as 1 spacer and 1 bearing seems perfect length.
Aluminumspacers.com has been good to me
The inner race of the bearing (small diameter that contacts the axel) is stationary, and basically everything else moves. You want the moving parts to not touch anything stationary because that creates drag. So near the bearing, use a “proper” part like a speedring or the spacer have you have. The rest doesn’t matter much, so your solutions of wide washers on the inside then spacer then bearing works fine. Make sure it’s tightened down quite a bit so the washers don’t jingle and/or slide around, and if the wheel still spins freely you’re good. I’m in the million washers club too
Thanks, I had a speed ring between the bearing version and the wheel bearings for that reason, if I thought it would be easy I’d take the inner sleeve of the bearing out and use it as a spacer. Just wasn’t sute if either of these options was better or worse and if they would affect the integrity of the axle. I preferred the bearing one as thought it looked cleaner. Seen some aluminium tube in b&q but from the reviews, wall thickness is inconsistant
Well taking the inner ring from the bearing was easier than I thought. Take the cover and retaining clips off then squeeze in a vice until its a bit oval shaped and the balls drop out. Looks OK too so will give this a go :grin:
false. 304.8 meters
4363.63636364 Big Macs
Once the retaining clips are removed, you can use a small poker of some kind to push all the balls onto one side of the ring. Then, the inner race is easily removeable without so much work.
So close……
Vruzend
https://vruzend.com/product-category/battery-kits/
Yesssssss that. Can never remember the name properly lol
Significant digits = 1.
300 meters.
