Nada for the size and style I need
Vbeltsupply and vbeltguys if you don’t have time, Aliexpress if you do have time
So everyone is using D&D without issues?
Yes
Yes
Been having trouble finding a DM
Direct Manufacture?
I just ordered from gpr industrial, they were cheaper like half the price of the vbelt supply
Edit: vbeltguys was cheaper then gpr industrial by a dollar, the vbeltsupply we’re almost double the cost.
Never had any problems with Vbeltguys or D&D belts. Would recommend both.
Is it possible to wirelessly transmit data to a DavegaX or other telemetry display? Like some sort of wireless UART?
You can use an old android connected via BT
You can take a allen key bit and put it into a 6 in one that should give you a good grip and will allow you to push in and keep the force on the striped bolts
Should I set my cycle capacity to 80% of pack capacity for a newer pack? 12s5p 21ah 80% would be 16.8ah, I’m only set to 90% 18.9ah for to see if there’s a range difference
As far as i’m aware, all that setting does is configure the app to report how much usable energy you have left.
If you are using the bms for discharge, the cutoff voltages are what you would need to tinker with to affect your usable power.
Is the any benefit or danger to having traction control turned on for street riding?
also in combo with smart reverse
How much street is street? I use pnematics on street and always have it on, also even in the urethane days i had it on too.
Pneumatics on asphalt(sometimes really bad asphalt) and concrete
What exactly does traction control do? Same as a car? Adjust speed of wheels independently to regain traction?
Hopefully someone who knows exactly what it does chimes in because I’m not even close to certain
Also interested in knowing. Saw a vesc setup guide that said to have it on but didn’t really explain why.
