Brilliant thx @b264 @rosco @glyphiks and @MysticalDork
higo or a copy of it, since there is no branding on it, but the pins are same location
Same layout but different pinout.
yes probably, i think i have the pinout somewhere, for the exway hub
I appreciate it, thank you.
This because the exway motors did not work with the Wowgo motor detection afaik. Daniel Kwan mentioned that they are using a different pinout than other motors using the same connector.
the problem with hobbywing is that, sensor ABC or 123 needs to be in specific order, it will cog if u switch it around
i did experiment on my old backfire G2T motor with few different hobbywing esc, all of them cog until i have it in the “correct” order
edit: also, i think exway hub is the only one that has temp sensor iirc, all other hobbywing motor doesn’t
Some of the Ling-yi escs will also allow you to go faster than the normal maximum speed while going downhill. Not sure what happens when you try to accelerate more on them while downhill since I didn’t try it for my old esc that 100% let you go over top speed. I would get to 44-45 km/h on some hills with it when the max speed was rated to be 42 km/h. (rated at about 26 mph max and ended up almost 28 mph downhill)
My current Ling-yi esc doesn’t seem to allow it but I also have a hall sensor issue on one motor that sometimes limits the speed. So I can’t say if it will also allow for coasting at a speed higher than the max speed.
Quick question, I have just made my first enclosure from fibreglass using polyester resin and am happy with the results, however… I thought as it was mdf, it would be a good idea to paint the mdf plug then clearcoat it, followed by 3 to 4 coats of a diluted pva then some wax to make it easy to get out.
Wasn’t so easy as the epoxy has made the paint tacky and left residue on the inside hence my question
Should I leave till the paint residue has dried properly then sand?
Or
Should I clean it off now and if so what can I use safely with polyester resin so not to ruin the fibreglass?
Tried a bit of 99% alcohol and that just smeared it
I’d try get it off with acetone
Ahh, will try that now, wasn’t sure if acetone would damage the resin
It might. Just be careful
Did you cut the mold like that shape?
Looking a bit better now, is it best to rince off with soapy water after or just leave it now?
Yeah, used 2 sheets of mdf and a router to make the shape then laid it on the deck and filled the gap with expanding foam, trimmed it when dry to get a nice seat on the deck
Never use alcohol on epoxy
Wow!
Do tb110s chunk really fast for everyone or just me?
