There is no hardware battery protection or hardware BMS functions on the ESC. Just whatever voltage cutoffs you set in the firmware.
Firmware wise there is extra c code in the hw_unity.c file for startup and shutdown of the anti-spark circuit driven by an LM5060 chip, but nothing referencing voltage/battery protection beyond what the stock firmware provides.
I thought it might have been a window for a display of some sort but I had no idea what the display was for since I didn’t buy it with one. The remote I bought for it has battery monitoring though so I don’t really need it anyway. remote and receiver it came with cannot monitor the battery
I didn’t remove it and fill it in with epoxy because it was already well sealed within the enclosure so it wouldn’t be a place for water to leak in.
I thought it was as bit odd if it did have a BMS built in but the language on the features was very vague and that port did remind me of what charging ports use. It being for a display makes so much more sense though
It is nice to have further confirmation that it does, in fact, have its own anti-spark and that the sites selling it weren’t making that bit up.
That is just a piece of acrylic and a frame where you’d slot in the display. I don’t have the actual LCD for it. It was either lost by who I bought the VESC from, or they were sold it without the display. pretty sure it just got lost though since he had to search for the BT module. IDC if I don’t have it though
It isn’t really any sort of priority to add one back. I only use remotes with displays since I am used to having battery levels and current speed visible on my remote. I don’t want to pull put my phone to check critical info.
They look cool, but I just don’t think they add enough to be worth the price for me. plus I don’t have a good place to mount one as I stand on top of where they typically go.
long time no post. As my interests come and go in waves and the esk8-wave just hit me again, I am back to seek some advice from the hive mind:
So I never finished a build using a hi5ber lotus deck. I am using large wheels, some big risers and custom straight brackets with nkp 3-links, mounting the risers and brackets on top of the deck, which means the board would sit pretty low to the ground.
I am using 63100 motors, so I am considering going above 12s and at least 6p.
My question is:
In your opinion, should I skip the risers and mount the battery under the deck with a custom enclosure (which I’d have to make), or should I get the 3Dservisas battery enclosure (which would fit the ESC enclosure) and mount it up top, keeping the board low?
(pic for reference - screws haven’t been tightened yet obviously)
You can adjust the foc → advanced → zero vector frequency
With “sample in v0 and v7” off, you can set the zvf between 20-40. Up to 30 with v0v7 enabled. 20 is loud and right around 25 it starts to get quiet, but sometimes the motors have a weird resonance with a specific rpm/zvf combo so you can experiment and see what works
Funny you mention that. I initially typed out the reply based on the Unity @ 30 kHz, but then I saw this and changed it to 40 kHz for the DV6 Pro
But yeah, he’s right. On a single MCU dual motor controller 30 kHz is the max, and on the newer Stormcores they are going with the STM32F427 instead of the F405 to boost the clock speed from 168 MHz to 180 MHz. Wonder if that’s in an attempt to make it run smoother at 30 kHz.
