Can anyone suggest a good battery level indicator, i had one that showed percentage and voltage but it broke from vibrations
Here’s a few
https://www.amazon.com/gp/aw/d/B06XCNZCFD?psc=1&ref=ppx_pop_mob_b_asin_title
https://www.amazon.com/gp/aw/d/B071HW4QHL?psc=1&ref=ppx_pop_mob_b_asin_title
they are both out of stock
All it takes a simple search of “battery indicator” on amazon and you’ll find them…
i know but i need one that doesn’t break
C’mon guys Stop with the nonsense and show him the good stuff ![]()
Get one and fill it with silicone
It is mounted on the board, but it is recommended
Open source davega, $30~ on AliExpress.
Ive never had any of the ones you pictured die on my due to vibration, only water damage cuz i didnt seal it right =/ i do have a new one laying around if you want the same thing again?
edit - nvm i see yur EU. GL
One yellow left!
I may have bought the others
well, that screen is made out of glass so it can break
oh that’s a cool thing. Do you use it? is it on top of your board?
everything breaks. the question is how soon.
I don’t really use it on a board, use it as a HUD for my utility vehicle running VESCs.
it broke after 3 rides
I have that exact one you pictured and it’s not made out of glass. Mine’s made out of plastic. Judging from the photo, it looks like the top right side was crushed?
the outside is plastic yes but the display itself inside is made from glass
The LCD (Liquid Crystal Display)? That shouldn’t really break unless crushed. It should hold up to vibrations very well.
The majority of meters out there are based on LCD because it’s cheap and simple. You might have to shell out a lot more if you want something.
