Yeah i know. All the enclosures either dont fit or look really bad
yeah i said eboosted above
My point was Peru, which also means a shipping charge.
true true
I hesitate to give this option, because the guy who makes these (Psychotiller) owes money to a number of people in esk8, but the guy @370HSSV who posted is totally reliable. Only deal with him.
yeah thats not bad. so I sound not go for the backfire one? I could always upgrade the battery in the future but itll be more money in the long runâŚ
the inside of G3 battery enclosure is full of half cut foam pads, and space is limited with the intention of only fitting a 12s2p (directly stacked) cells. any future upgrade using that enclosure maybe be more work than if you go for eboosted/ psycho/ bben enclosures.
thats true, ill probably get a custom battery now that i think about itâŚ
@maxmayer I might be able to get you what you need but youâd be narrowing your options for sure.
I can probably get you a 12s4p nese pack (no BMS) and eboosted Evo enclosure for $350, but I donât know if I would recommend it for newer builders
Yeah I would rather having the BMS, thanks though
Any chance you could add the BMS into it?
I donât have a BMS sorry but honestly though man, what were your plans for a diy? Because if 350 is the budget for the battery and enclosure, whatâs the budget for your esc?
Iâm not trying to deter you from doing what you want to do, but diy is expensive and frustrating and the exway flex is a great board among others.
FWIW, I already gave him some advice, sent him here, and different pack quotes. He seemed real concerned with getting scammed, so maybe Scept being local will work better for him.
As a proud owner of 2 10s5p by DIYE boards.
They arenât bad. I mean theyre fine packs, but there are MUCH better options.
Super large for a measly 10Ah
At what battery percentage do you hit sag? My Diyeboard pack dropped off a cliff after 60%.
I mean I donât have a real budget, but I would like to save money yk. My ESC is 110 from flipsky (they gave me a discount on alibaba). I donât want to be scammed but I guess trial and error is part of DIY
yeah I encountered that the other day. @pookybear and I got to walk up about a mile of 30% incline -_-
Good to know my packs arent broken. lol I do run 2 of em in parallel which helps.
speaking of parallel battery pack, do u mind helping me with this question?
errr probably fine if they sit behind their own charge BMS systems.
But thats just a probably.
If I had a schematic I could be sure.
I would recommend charging them separately to be safe, especially if you already have 2 chargers.
I charge separate. Any reason you want to charge with them connected together?
thanks for ur input man
the reason i want to charge them while connected is because im too lazy to unscrew the enclosure to unplug it lol
