Backfire, sorry im a bit lazy
Ahh ok, I really like that backfire battery and iâm fine with its length because I have a 42" deck. Its just that i dont know how much range I would really be getting. Also the enclosure it not boring or blocky looking like most other enclosures i would need to buy for a custom battery
Consider a custom battery with custom enclosure to be twice $$compared to BF,meepo, etc
also, I would not expect the light on the G3 battery would work as intended even if u have the correct connector for it. Its most likely firmware based setting on the hobbywing esc. ( I might be wrong tho)
Youâre probably correct, they said I prob wonât be able to control it, does it have manual controls?
Yeah⌠too much for my board.
thatâs outside of my knowledge
Ok thatâs alright, they said the same thing. I could ask again, I doubt I could use it though.
Avoid this turd at all costs. Itâs from a time when there werenât many options, like late 2017. In todayâs game, this is a terrible battery.
Thereâs a strong battery builder in NYC. Iâll check if heâs taking on orders currently.
Ok i will haha
Ok thanks. Im considering the backfire 346wh battery, its 430 with enclosure. Cheaper then a custom?
We screen dudes pretty hard here when it comes to batteries. This should not be a worry of yours.
Sorry to hit you with another negative point, but you also donât really want that enclosure, as it limits your options later on. Youâll be stuck with that size battery.
hmmm, thats true. do you reccomend any enclosures that are not boring boxes?
yeah but ben is in uk soâŚ
shippingâŚ
EBoosted is in Peru, unless he has stock in TX. It kills me that we donât have a US-based enclosure maker other Psychotiller.
