Hello there!
After mowing quite a few lawns I’ve finally scraped together enough cash (as I was adviced to do a few years back on the previous forum) for what I believe to be a board that will serve me well and last quite a while. Most of the parts are in the middle of shipping or have already arrived and have been selected based on the positive reviews I’ve seen.
- Deck: (for now, the enclosure fit is a little janky but works): Longboard Comet Grease Hammer
- Wheels: BOA 100mm
- Enclosure: electricboardsolutions ABS ENCLOSURE 50X15X4CM
- Motors: MAKERX N6354
- VESC: MAKERX GO-FOC DV6 (regular 100A one)
- Remote: Flipsky VX1
- Trucks/Pulley/Etc (seen very mixed opinions but it came with a very generous discount): MAKERX M-TKP POWERTRAIN
- BATTERY: 12S4P, Samsung 30Q cells (Samsung INR18650-30Q 3000mAh - 15A - 18650 - Li-ion - Rechargeable batteries | NKON) BMS: LLT SMART 12S 20A
Battery build background
I’ll post more info and pics once the build is done, for now, I would love some general feedback primarily regarding the battery. I was planning on building it myself taking advantage of the smart brains and tools available at my university. The design takes heavy inspiration from eBoosted and tkc (12S4P battery build help - ESK8 Electronics - Electric Skateboard Builders Forum | Learn How to Build your own E-board). Ironically, none of the smart brains I asked at my uni seem to have a clear answer to the nickel question.
For the most part, I am pretty confident, but I’m a little unsure of how much nickel is needed between the series connections (and even the parallel connections). I have access to 0,15 x 8mm nickel strips. From what I’ve read, one of these strips is optimal for 5A. Using that logic, I’d need to stack 6 strips parallel (12 in total) to be within the optimal range to handle the 60A that the battery can output (15A per cell * 4 cells in parallel). But this seems very unreasonable, and I suspect it’s because I’d never be pulling 60A for more than a split second if ever. However, that begs the question, how much nickel should I be using? Is it even advisable to stack nickel or should I spend more time trying to find bracket-sized pieces, and how come? (as seen in How To Build a Compact 10s4p 18650 Electric Skateboard Battery (DIY Tutorial) - YouTube by RB E-Motion). Or do I have a huge knowledge gap that I haven’t acknowledged?
I’ve seen some builds only using one layer of 0,2x10 everywhere, some using three layers of 0,15x8mm, and also soldering 12AWG cable across the series connection. I’m relatively confident three layers is enough between the series connections, but with no other reasoning than it feels like it. And even then, aren’t these extra layers more likely to come loose and thus may be more harmful? If three or even just two or one layer(s) is enough, how can I avoid disaster? Is this something that can be setup in the VESC, allowing momentary high discharge, and if so, how is this ratio determined, or is the occurence so rare it’s irrelevant?
I apologize in advance if this is a question with an obvious answer but I believe I have scoured the search engine to exhaustion only leading to varied answers and for the sake of reducing the odds of an inferno I’d love to have your direct input.
TLDR: How many layers of 0,15 x 8mm nickel strips should I use between the series connections and why?
For your convenience, cell specs:
| EAN / GTIN | 8438493100389 |
| Brand | Samsung |
| Size | 18650 |
| Battery chemistry | Li-ion |
| Battery | Rechargeable |
| Voltage | 3.6V |
| Min. capacity in mAh | 3,000.00 |
| Battery version | Flat top |
| Discharge current | 15.00 |
| Circuit protection | Unprotected |
| Height in mm | 64.90 |
| Diameter in mm | 18.30 |
