That diagram is for a common port bms, looks like yours is seperate and should look like this. WITH FUSE on positive charge wire (right side)
Minus the 3 extra batteries. I got two for my setup. For the balance extenders and balance wires from the BMS harness. Do I still add three wires to the extenders? for example battery 1, I need to have red, white. white, white, thatās 4 including skipping n5, so do I add all of the balance wires? another example (trying to keep it simple as possible) for battery 2, I have to add the same shit, n1, n2, n3, n4, n5. n5 being the black wire. Or I have to do a whole separate configuration since Iām only using two separate lipos? Also another question. Could I splice the positive wire for the charge port to the main positive for the battery harness?
Alright. That diagram you sent before is similar to my BMS, most likely will make a thread about my question, might help other people with the same issue Iām having, this is like the only thing stopping me, after this. Few detailing and my board will be done
Just saw this video after checking out this thread⦠some interesting ātechniquesā used by chiā¦
Believe it or not, thats actually better than iāve seen in the past
$450 btw
Credit to @TheBoardGarage
Chabuduo.
Dont those packs get really squished into the enclosure by the lid, as well? That seems super un-safe.
Just to be clear, youāre talking about the couple of balance wires that cross over each other without insulation, right? As for the main balance wire runs Iām not sure how else you would do that
I also think that the lid does press quite tightly down but Iāve not built one yet, so who really knows
Yes, thatās what I am talking about.
There are more than a ācoupleā wires crossing here lol. Definitely not a pack that I would feel comfortable pressing on at all.
I also have not built on. I seem to recall hearing from others that fitting a chi battery in a onewheel requires a lot of pressure on the pack, but maybe that has changed.
@TheBoardGarage youāre the only onewheel expert I know. Can you weigh in on the pressure that a chi battery will be under when installed/having someone stand directly on top of it?
Well right, basically all of them lol
Awesome video brother.
Youāve just set in stone for me that iāll never make a onewheel battery
I think you missed the point hear
RISK ASSESSMENT
Most common way is to assign a number 1-5 for the likely hood 1 been unlikely 5 been very likely to happen
Then aside a number to the severity of the out come 1 been not that bad (board turns off) 5 very bad (flaming ball of fire running down the road
PVC balance leads melting
Chance 3 severity 4 =12
Silicon balance leads melting
Chance 1 severity 4 = 4
@Gamer43 has reduced the risk by useing silicon wire. Is the risk low enough?
Even if the wires were keeper apart as you say the risk is still there as thay could move so itās still not a 0 risk A* pack
Things that make you go hmmā¦
Some other top end brands epoxy the battry to make the water proof. now if a cell vents you made a pressure vessel than could go off throwing sharp debri. Just like a had grenade ![]()
Sure. I hope this helps.
Thank you for that video!
Has anyone created a 3D-printed āgasketā that can raise the metal lid by a few mm? Or would that create other problems?
This thread is fascinating. If youāre forced to cross wires and can use silicone that, in my mind, negates a great deal of the risk as silicone stands up well to abrasion and heat.
Question tho- under what conditions would a battery get hot enough to melt pvc during normal operation? Iād think if your battery is hot enough to melt PVC oh, you have much bigger problems then worrying about your balance wires. In my mind, the most significant issue given the environment in which these batteries operate, is abrasion resistance.
Agreed. Though I would be concerned that the PVC could soften at below its melting point. The pressure and rubbing could then push aside the insulation and cause a short.
If cheap 85°C-rated PVC is used then could there be a concern at, letās say, 65°C? I donāt know when PVC starts to soften.
The cells wouldnāt necessarily have to be at that temp either. It could be the nickel with the current concentration at the weld points causing localized high temps.
I donāt know if any of this could happen. It certainly wouldnāt happen often. But I think itās a possible concern to consider if using cheap wire and when locating the balance leads.
Gasket was the glaring obvious thought in my mind too. There must be a reason why no
Yep they are squished quite hard⦠when I made those Onewheel XR packs a while back I made sure every single wire was insulated to our standards
