I see, even more interesting, awaiting eagerly
Solid information. Looking forward to the new design. Can you tell us the dimensions?
I like the new design I would fuse the USBC port and where is the pwm port?
…a case which is a truck riser with the ‘based on’ vesc inside?
yup, that’s our plan
Sounds great (even more after seeing the pictures above), looking forward to it!
Very cool seeing some of your designs. I have seen some of thos before, wasn’t aware it was all the same dude. Working with their inverters, I can say that Toyota tech is practically indestructible. Can’t wait to see that expertise applied here
You don’t have to warn is about flipsky there are a lot of issues with their products. Voltage regulators that die resistors too low wattage, poor quality capacitors. Poorly soldered USB headers.
Will be waiting to have more info about this!! Looking into building my onewheel diy… just waiting for your website to get a new stock! LOL!
These are used for diy onewheels there is a video tutorial and everything
Any progress in relation to this?
what is the difference between cheap FOCer 2 and balance pro 6.6+
Balance pro is square.
Cheap foc is cheap yo
Without heatsinks the focer can handle much less current, after adding heatsink they are closer in amp capabilities. IMU used may be different.
I believe the cheap focer has a on/off button where the balance pro needs an antispark or loopkey.
so basically there is no difference if I am building my onewheel
I thought that was just in the little focer
do we have a Gerber file for little focer
its expensive
Nope, its how the funwheel builders turn their boards on/off
