Yesā¦ That would blow it up, either take a <200mA power supply or replace the SMD Resistor RPROG with a ~5kOhm one for about 250mA charging
not a n00b questionā¦ but a question nonethelessā¦ anyone know the smallest BLDC motor that VESC can operate?
Specifically a 2306 2300Kv ??? eRPM problems at 10s?
96600 RPM is more of an issue unless you have a 600 tooth wheel pulley.
Brian you gave me a stupid idea. A little wind turbine that plugs into the microUSB port that charges the remote when youāre movingā¦
Just put the turbine on the board and charge the board with it. That way you have infinite range
/s
science says that cannot work
yeah I hear yaā¦ can a VESC operate at 4s?
That would be the easiest solution to the eRPM issue
Just reverse and bypass whatever penny circuitry is in there to protect reverse current (if there even is one)
Plus you get bonus cool guy points. Perhaps you could wire it to the top of your helmet for maximum style.
You know what. Iām bored enough to try that. If that prop doesnāt work I can probably design and print a 360 non directional turbine for itā¦ Tiny little 5v boost converter and voila the dumbest remote accessory
I have seen ebike lights with built in wind turbine on AliExpress.
#Aliexpress AU $7.39 5%OFF | LED Lights work driving lamp Wind Powered 2pcs for kia sportage rio 3 4 sorento ceed cerato soul Automobiles&Motorcycles
Iām confused the link seems right but I donāt see an oil slick option. Has @Venom121212 finally cracked?
It can I do all my initial vesc setups and testing with my spot welder PSU same voltage and current ast a 4s lipo
When you think you have an original idea but they already mass producing it in chinaā¦
arenāt vesc based escās yuuge compared to like a x-rotor type esc? i assume thatās what youāre tryna do, power a multirotor
iāve setup and uploaded firmware to a tb4.12 hooked up to an alkaline 9v cell, for what itās worth
NOPEā¦
Iām doing sumpinā "for science" donāt waana brick a +$100 motorā¦ so I figgure Iāll see if I can test and log a $10 quad motorā¦
also donāt waana brick a FocBox so Iām keeping my fingers crossedā¦
in some respects qwad ESC software is way more superior to VESC, but for logging and testing I need something I can manipulate and logā¦
but thanks for paying attention
quad motor
FocBox
4s battery
hold my beer Iām going inā¦
i consider it a real honor to hold @kookās beer
i have my fingers crossed that you can get the commutation of all four motors synchronized on one focbox
Only 1 at a time āfor scienceā all 4 on 1 motor controller would make a variable speed fanā¦
EDIT:
4s works! I perved around a little and in the battery section the options go down to 1sā¦ just leaving breadcrumbsā¦ VESC lower operating voltages go down to 1s
Anyone here knows where to get a dirt cheap female servo cable?
