Yes, thatās the good stuff
Also read this
Also read this
Because itās far more likely to break
Why dont you make your own threadā¦ After reading someā¦
this
and this
@olsyke you donāt want the failures caused by silliness like that.
Reliability > Appearance
Itās not only appearance @b264 a narrower rear offers some interesting handling opportunitiesā¦ Most all off them goodā¦
Narrow front wheel no goodā¦ = shopping cartā¦
Narrow rear different, but not that bad handlingā¦
Actually, I prefer the feel of narrower front trucks. Iām surprised to hear you say this.
Sounds like we need a thread for this.
Narrow rear and wide front feels mushy to me and likely to get wobbles.
For aesthetic reasons, wider front looks better by farā¦ but I donāt like the handling
for me itās the oppositeā¦
the most stable geometric shape is a triangle (Yes Iām grasping but I think you understand)
look at those 3 wheel scooters and stuupid looking 3 wheel yuppie motor-cycle things
as for wobblesā¦ where is your weight placed?
what is going to go straighter a triangle or a square?
narrow wheel bases rockā¦ look at where DH is now?
a split-angle truck, a narrow rear, weight forwardā¦ itās a missile set-up
Iāve be experimentingā¦ Itās differentā¦ but I kinda like itā¦
and NOā¦ Iām not going to ride one of those freakish 3 wheel shake-boardsā¦
unless it will make me faster than stink
I love the polaris slingshotā¦ Thing is a powerslide monster. Itās the closest thing to an auto sized go-kart
lime green polyester pants materialā¦ ohā¦ I forgotā¦ youāre from the OCā¦
I understand nowā¦
Iāmā¦ wearing polyester pantsā¦ goddamn it
all the wayā¦
I grew up in Zooport, I feel your painā¦ jajajaja
You can get out of OC but you canāt get OC out of you
FUK Iām OG OC B4 you were a thing!
I guess we used too many So Ca~isms we lost @b264 and our discussion about that other guys freakishly narrow rear endā¦
hows this different than the gt2b?
Looks like a cost reduced version of GT2B.
GT2B is 3 channel and has rechargeable battery.
GT2E is 2 channel and uses AA batteries.
From details I found on the other forumā¦
Edit : they report notable internal construction and functional difference related to failsafe.
nice find!
Yes, 3 wheel with the wide part in the front definitely looks better, and with rack and pinion steering itās most definitely better.
However, with lean-initiated turning, I find the narrow front is more stable. The wider rear truck seems to help damp out wobbles and the narrow front truck gives excellent fast response to steering input by the rider.
Still looks better with a wide front, thatās a shame. Iāll take the thicc rear-end any day as long as itās narrow in the front.
First build Iām going to use tb6374 and battle harden then Iāve found threads and videos on that part what I cant figure out is how to do conformal coating looking at using 419d most likely oh not my picture
For motor windings, MG Chemicals #4228 works well
