im unsensored btw, using vx1 in ppm
yes it happens when Iām feathering the throttleā¦goes away when I push all the way. Iām running sensorless.
Can you share a video of calibrating your ppm remote from the app?
And a screenshot of the motor config.
yea can do that, but not right now
first thing i will do tomorrow
@Deodand would you recommend after that to upgrade my firmware ? should be a few weeks / months old
I will reccomend everyone to upgrade in a couple weeks once we get some quirks ironed out. For now unless you want to help us refine it and test then do not update.
i dont have metr so i dont think i would be a very valuable tester, but if im mistaken there i can gladly help out
I donāt think a metr is needed. If you just download this latest tool and give it a go that is always helpful, but as I mentioned its still in testing face so you might run into something weird. Just be aware you are accepting an amount of risk trying something new. So far my testing looks good but your mileage may vary. Also, you can revert back to the unity FW at any time.
i will give it a go i guess, allways wearing full protection and with the recent stuttering im riding very aware anyways
will still do the video tho before i update
Yes if the stuttering persists across FW update Iād take a hard look at the remote signal your remote is sending.
@janpom
Where can I (I guess itās the COMM port on the VESC with 7 pins for me) some male and female headers in order to make a extension cable
search ājst-ph 7pā on aliexpress
Does anyone know of press-fit, kegel-core wheel pulleys will work with @torqueboards 218/220 trucks?
edit: just found this: Torque board question
Are there other options besides Janux?
Pretty positive the 3DServisas ones do as well
Vesc 6, should traction control be enabled on both vescs or just one ?
Not a noob Q, but donāt want to make a dedicated thread:
Hummie deck. TB110 wheels. What drive-train would you guys recommend?
Board will be going up and down curbs a lot, and for a friend, so I donāt want to do maintenance once itās set-up. Is direct drive my best option for clearance? Problem is that I couldnāt mount it drop-through (Unless I go DKP, but that would look too long I think) What would you guys do?
Iāll tell ya what I thinkā¦ but your probably not going to like itā¦
direct-drives arenāt really suited for that in all reality, all that unsupported-cantilevered weight on the axle can be very problematicā¦
Is that actually an issue in reality? Donāt think Iāve seen any bent TB DDsā¦
well think about itā¦ youāve seen bent trucks, now take away almost all the hanger and replace it with a non-structural motorā¦
i donāt know if itās me or a language deal, but from where I come from up and down curbs means jumping, like at least one axle leaving the groundā¦
I donāt jump in reality, but I have bent an axle, however not a TB DD
iām just saying
Tbf I think my friend weighs less than @DerelictRobot, so if theyāre good enough for him, they should be good enough for my friend.
