Sounds good, would it possible for someone to explain how that would work?
so four ports, one charging port with an xt-90/60 and the bms cable, a second charging port with the same, a loop key port and a port to connect the cable to the ESC?
6 holes in total; 2 pairs of XT-60 and balance wire connectors for the BMS, 1 loop key port, and finally the port to connect to the ESC in the 2nd enclosure
Edit: thought you had counted wrong, but it was I. You got it
Id say they are all about the same at the end of the day. Just matters how the vendor deals with issues. So Id go for TB over all those 3 companies.
Sweet. thanks so much
Hey, could someone be so kind as to direct me on how setting up VESC with Ack is different for V 6.6 HW than V4.X HW? Iāve used this walkthru a bunch for VESC 4.12
But Iām using a fsesc 6.6 and am not sure how setup is different for this HW. Thanks
RN my computer doesnāt even recognize a device is connected. The cable and ports are fine, I tried connecting a focbox with same cable np, so itās something with the fsesc 6.6. I have a mac. Donāt think flipsky customer support will be much help, anybody got any clue on this?
maybe thisā¦
https://www.amazon.com/gp/product/B07NQ2GB6Q/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Do you have $20k to drop and a large set of titanium testicles? Because if not, then you canāt
Better make 'em out of tantalum just to be safe
Have to check later with another belt that has nothing on it.
Well i forgot that i canāt check it because i donāt have any spare belts left. Can tell you once i ordered some
So my vx2 pro is refusing to turn off. I was out for a ride and i got a low voltage warning saying the remote was at 15%. I went home and put it on the charger.
The screen now says LOW VOLTAGE, THE REMAINING POWER IS LESS THAN 10%! It will not let me turn it off, but I can still control my board. Should I let it run out of power for real, or will it not know it is getting low and to turn off ending up damaging the battery?
Iād say let it run out. The battery voltage is a fair bit above critical voltage.
Anybody interested in a trade? Single Turnigy sk3 192kv 6374 Motor against 2 smaller Motors (no specific brand)? Doesnāt have to be 1:1
when I pick up one side of my board sometimes the motors donāt spin. They are getting signal but not moving for some reason.
what might this be?
or is it normal?
not clear what youāre doing lifting one side of the board up but I wonder if that engages the traction control
yeah thatās the main thing I was thinking of but I thought I had left traction control off.
I think it might have something to do with the lower voltage, before it did AWD burnouts no problem. I will test it out more tomorrow. It was weird because I did not seem to be doing that before but itās possible I did not notice.
Anyone got a koowhel 2nd gen motor connector pinout?
Trying to see if the hubs are shorted
