K got a couple of those for around £5 and will see if they work if not I can go back and work out another way
Yeah, those parts are MBS knock off parts. Unfortunately it’s tough to say what the specs would be or comment on compatibility. Not much help I’m afraid.
Why is it so difficult to buy 480mm belts??? All i see is 475mm except for one shop.
are these the ones you are looking for
Kinda yes. I’m not a fan of the 15€ shipping and 2-3 weeks shipping time though
oh… sorry bruh…didn’t know you were in Germany
Don’t worry, you are not the first one
Should’ve stated the location.
Take the motor apart. You will likely need a circlip tool for that, and a spare motor mount that isn’t attached to a skate.
thanks mate, im gonna buy this one and see what come off
Anyone have any ideas? Have gotten some random DRV errors lately since bumping batt max to 25a ea side and -15. 3p 30q
No errors this ride. But getting a jerky studdering acceleration. Feels like one side is working inconsistently. I see differences in the motor amp and battery draw per side. Especially when screen shorted here
Is scratching the nickel necessary?
Over the winter. I left my board at about 33v (10s4p lithium ion) then about half way through winter I noticed my board was at a very low voltage so I charged it and forgot to discharge it back down. I left it at about 80%. Recently I switched to a smaller motor but I’ve noticed my battery life is not nearly as good as it used to be. With the smaller motor, I am giving a lot more throttle (almost full) for hills and acceleration with my other motor, I used to use about half throttle max. I also had the same 60a max battery output. Could my battery be worse because I’m pulling more amps then I used to be? Or because I didn’t leave it at 33v all winter? Or maybe both?
I’d there any way to run diagnostics on a board? My friends board froze mid ride, everything is running fine now so I don’t know know how to check it
Plug into vesc tool and type fonts in terminal. But they get wiped if the board power cycles
It’s running a push start only antispark so I only have 10 minutes or so…is there any other way?
Download CSV files to phone through BLE?b
Oof how do you do that? All I got is a BKB HM-10
