Archived: the OG noob question thread! šŸ˜€
i did that but velcro is not strong enough by itself it is useful for keeping cables down though and holding the vesc in place
Hey guys,
I am trying to set up a VESC for the first time using the VESC-tool. However I am having issues updating the firmware. When i plug the vesc in i get a prompt telling me to update the firmware. When I go to update it the update starts and after 10 secounds i get a promt saying ā€œErase timed outā€. I can’t seem to figure out whats wrong. I have a maytech v4.12
anyone know hobbyking mount centre to centre distance?
Newest Vesc tool? I had the same issues, and went back to the safety of 0.83 immediately.
You can find it or newer versions here:
wondering how much range i can expect from a 12s5p 30q with 6x2 aliexpress wheels
i need 30miles around and have a cutoff at 34v
do you think i can make it on a relatively new pack
if you were to do 15Wh/km you could get 43km ish of range. probably more if you have flat roads and don’t weight much (less than 62kg)
to acheive 30miles you would need 13wh/km average on the calc.
weigh less and currently doing 26wh to the mile with half flat wheels
what do you think if i pump them up and ride cleverly
what’s that in Wh/km lol?
i don’t know how to make the conversion… well i think i do lol hang on
so you currently do 41wh/km?? you’ll not have a chance if my caluculation is right
no do 16wh per km
oh lmao i multiplied :rofl:
yeah you should be able to do that
I get 12-17Wh/km and reach 20-27km with a 12s1p lipo. Cutoff at 42/40v. And i weigh double as much.
10s4p 30q gets me around 20ish km. (although i ride fairly agressively)
Awesome i’ll try that! Thanks
so you think i should be good its around 50km
Probably. Pump your tires up more, don’t race the cars and you are proooobably fine.
It works now! Thank you so much:D
what are the pros/cons of 2 x single esc’s over a dual? been looking at the neobox dual or 2 neobox v6’s, price suggests just 2 v6’s, but maybe im missing the benefits of a dual system…
fair question and everyone has their own opinion and here is mine, i’m ignoring cost as that can fluctuate.
2x single
Pros: if an issue arises in one you are able to pivot to single motor temporarily.
Cons: potential for single point of failure, sometimes a larger footprint than dual
1x dual
Pro: smaller foot print, some have integrated components like anti-spark
Con: potential for single point of failure.
sorry if ultra-noob question, but what is a ā€˜single point of failure’? like what would be an example?
Any 1 part of your project that stops you in your tracks if it fails.
So if you have a dual motor build and one motor dies, you can still limp home fine with one motor.
A single motor build will be useless if the motor dies.
In the single motor case, the motor would be a single point of failure.
If you cut a wire into 6 pieces and solder them all together to make a wire again, you have created 5 more points of failure.
