ah ok, thanks.
so pros for dual = sparkplug / pros for 2 x single =less chance of total failure - youâre unlikely to blow 2 escâs at once.
Thatâs the running theory. Youâd think makers of dual escs would make them able to still function in case of one side failing but none yet. There is a wave of new escs coming though so who knows whatâs on the horizon.
If I have a dual motor setup with a 60a output battery. I would want to set the motors to pull 30a each. Right?
depends on your esc
If I were to set each motor to 60a wouldnât that pull 120a through the battery? Itâs a fsesc
Does anyone have that much movement ? (matrix 2 with oil slick baseplate)
my hanger has no play (zero freedom of movement on the front/back axis) but my hangers are black and my base plate is plastic
How do you calculate Max current from battery? I have 12s5p with 30q cells
30q cells have a continuous discharge of 15amps and burst of 20amps
So 15amps * the 5 parallel groups = 75 continuous amps
And 20 * 5 = 100 burst amps
Yes, a few others have had this on the black as well. If you can tighten the kingpin to where it doesnât do that, great. If itâs too far of a gap and youâre not comfortable doing that, hit up mbs about a replacement as long as theyâre still fresh.
Well this is already the replacement. I got this one from @Mainflow because his was bent. I got the bent one (hanger is bent) but use just the baseplate
You could warm it in the oven for a bit so it wants to bend easier, crank the kingpin tight to close the gap, and then let it cool that way. Not sure on a recommended temperature to bake at though.
My oven is brokenâŚ
Also mbs doesnât seem to answer my emails anymore.
Somehow everything i touch from mbs is fucking broken.
2 sets of tires - bad batch and crooked.
Mbs baseplate cracked
metal baseplate that doesnât fit
like wtf.
Maybe we should stop speaking⌠Iâve had great luck and donât want to mess that up
Want that too!
Also the fivestars i ordered. The shop i ordered them had the listing up, 3 days after purchase they tell me
âHey we donât have them in stock until end of Aprilâ
MAYBE UPDATE YOUR LISTING ffs.
I think i hopefully fixed itâŚ
I printed 2 washers that go between the bushings.
1x 1mm
1x 0.8mm
now the gap is filled. Now i need to test it while riding
https://photos.app.goo.gl/rxw8dyWQpB9mBSXM9 any idea whatâs causing this noise. I have only had the motor for a week or two and it started as a whistle but is now really loud when Iâm on the board.
Hi! which charger would recommend for 10s5p?
https://m.aliexpress.com/item/32991383938.html
https://m.aliexpress.com/item/32865210438.html
Personally⌠Id get this guy or higher A(amperage) if you wiring harness can handle it
https://m.aliexpress.com/item/32978454266.html
Or if youâre a dirty American with ineeditritenowitus ,
https://www.amazon.com/WAOUKS-Charger-Lithium-Auto-Stop-Aluminum/dp/B075RZVS3L/ref=mp_s_a_1_3
No. Motor amps can exceed battery amps, but not vice versa.
You set battery amps 30a per ESC and for the motor amps you set whatever you want up to the max amp rating of each motor, that controls your acceleration.
