thanks for the recommendations! would you know approximately the charging time for each charger pair 10s5p 30q?
One of these three answersā¦
Bout tree fiddyā¦
Bout an hourā¦
Iām too tard to do 2nd grade āxā based mathā¦
I think itās the second but somebody with the formuoli can come tell ya fer sure⦠I gotta figure out what drug you smoke for proper sleep.
Do not go above 5A charging if you are unsure of your wiring harness or if your charge port is a barrel (laptop charger style) jack.
If I set max motor amps to 80, but my Max battery amps to 60, how will adding that extra 20 make a difference?
So I was thinking about this. If Iām starting from a stop, Iām not using many volts but Iām using more amps, so does it convert the energy to have output more amps and less volts?
Be sure to check out the search once you have some key terms but fine to ask here too or ask for elaboration in the thread.
Roughly speaking yes it uses less effective voltage at low rpm on the motor side, also motor coils make it an inductive load and other details in the thread.
I like how when I opened the thread, it just brings be back to this thread
Heh yah thereās posts under the links but I see how someone could get stuck in a loop
But thank you for that, to be honest, up until just recently I thought motor amps and battery amps were the save
No problem definitely a confusing nuance at first. Way to go is just set battery limits based on what your cells/battery can handle safely with regards to charge and discharge keeping in mind peaks are typically short and I set motor limits so I donāt get thrown off accelerating or braking.
Okay, I appreciate your time
The math is simple:
Ah (Amp hours) of pack divided by A (amps) of charger gives you the ⦠h (hours).
For a 5p of 30Qs the Ah of the pack is 5*3Ah = 15Ah.
So if you have a 3A charger, thatās 5 hours.
Two singles are much more repairable if/when something breaks and you donāt have to replace both if there is an issue with one. Often you can ride home on one side if there is a malfunction. Esk8 stuff fails all the time and a dual turns into a brick if there is a minor problem instead of being able to fix the side that is broken.
To be fair if half of my esc fails Iām calling Uber. If a belt snaps Iām calling Uber. Aināt sitting on the side of the road reconfiguring to single drive and/or troubleshooting errors on my phone. I bring a small tool pack with me for small issues but a catastrophic failure like that Iām over it. lol
- Assuming the failure did not catapult me and I need to go to ER
I donāt take boards apart on the side of the road either apart from some minor issues like changing a wheel bearing or maybe a belt⦠Lyft is greatā¦or often the dual will just make it home anyway with only one side workingā¦without working on anythingā¦
But then once you get home, youāll be kicking your own ass that you decided to buy a dual and now you have to buy two more ESCs instead of one more and do all the labor and installation and programming and everything that goes along with it⦠twice⦠instead of once.
Disregarding the actual cost of the part, labor is similar? no? Say 1 side of 2 blew, you will need to disconnect battery line, phase lines, 1 canbus, and program the new esc once.
A dual blows, you will need to disconnect 1 battery line, 2 sets of phase lines, but no canbus, and here is where it gets tricky. IMO a dual should only need to be programmed once (i.e. unity). A dual should not need to be programmed twice. Thatās called 2 singles on 1 PCB.
Thank you for your help!
Would an 8A charger harm my batteries by charging faster?
Which pin of the charger is the most recommended?
I donāt even see the schooner here.
Does anybody have a good website to buy motor shafts?
Europe preferably.
I need a 10mm shaft for 6384 (APS) that steps down to 8mm
This is a follow up to this
What thread type is the Matrix II axle? I think M10x1.0 but not sure
And where can I cheaply get 8 of them?
M12 thread.
