So my single motor gets very hot and surpasses the set temp limit and causes cutouts. to avoid this I simply unplugged the sensors and itās been fine but now I have to deal with sensorless operation.
I donāt think itās an issue, but would re-attaching the sensors and setting the temp limit to 999c cause problems? The way I see it is if itran fine unsensored at high temp then it would run fine with sensors at high temp.
When you unplugged you sensors, you unplugged the temperature sensor. So you could be demagnetizing your magnets if they get too hot. I donāt know though how hot itās getting or what magnets you have.
You can plug the sensors back in and still run sensorless, except with a temperature sensor.
It getās extremely hot but I have not noticed much power loss from demagnetization. Itās the ābattle hardenedā maytech 6880 so I hope there wouldnāt be an issue with magnets falling off or anything wonky. Time will tell.
You mentioned I should go with 140kv if I run sensored and with big wheels. Could you explain that for me as I would think bigger wheels would require bigger Kv?
Thank you @Flasher! I will need to read more about KV and itĀ“s effect on performance. Will go through the search function and come back in some days. (if anyone has a great link on that topic would highly appreciate that).
So I bought these cheap velcro cinch straps to hold my enclosure temporarily and a couple of the loops have broken already from riding. I JB welded one of the broken loops already and will test it later to see if it worked or not.
@b264 youāre the JB weld guy - do you think putting a coating of JB weld on the loops as reinforcement would be a good idea to prevent any more of them from breaking?
JB Weld is more like concrete, itās great under compression but not as good under tension. If you used zip-ties as suggested above itād be better I think
Iām a little slow sometimes; Iām not sure Iām seeing how to implement these on the plastic loops? wouldnāt I need to effectively replace the entire loop with two of those u-bolts with something connecting them on the top and bottom to make an entirely new metal loop?
Anywhere you see a plastic loop, cut it and put a metal chain connector in its place. They have the same size and shape, but easily 100x the strength
Edit: its just a 1 to 1 replacement, go to your hardware store and look for something similar that has the same interior length (long straight sections) as the width of the strap
