I am completely lostā¦ using a mini VESC 4.12, and an 80100 motor. Sets amps to 45/-15, but whenever I accelerate somewhat fast and break somewhat hard I get cutouts:(
The amount of adjustability is higher on our spring trucks. Inner and outer spring position, 7 different dampas, adjustable pre-tension and Barrels option. If you canāt find your perfect setup, donāt blame us. The Barrels are either super turny (inner position), or medium stuff in the outer position.
is your absolute max setting a lot higher than either the motor and battery amp limit settings? it should beā¦ like 120a or more.
The Trampa Barrels are the same thing, just less expensive. We are also in the process of making custom Barrel designs.
perfect! I never said i had a problem, in fact i really like your trucks
My preference of barrel for me at this present stage are the etoxx ones though, that is all i was saying
They are made on the same mould.
but only if i pay 10 bucks more for a different baseplate?
Whats the 30gbp difference between the Infinity and Vertigo truck? That the one is CNCed and has hollow axles?
Itās 130
do you have a battery management system controlling your discharge?
do you think with voltage sag the battery is dropping below your minimum voltage setting? other than that all i can think of is temperature cutoff.
There is a thread for it
What vesc is this? Are you getting any errors in the vesc log?
I doubt it, because it happens when I break also
@Harrisonwms1 since you said it happens during āhardā acceleration and braking, it sounds like a result of high current which would either suggest a temperature issue or a software issueā¦ one last possibility that comes to mind is the firmwareās hardware limits file of the hardware youāre usingā¦ if youāre exceeding one of the settings they have in there, it could possibly cause an issue. iād try lower current limits if your bms really isnāt limiting charge/discharge.
Is that how you refer to me at night, when noone is around?
I havenāt thought about firmware issues, I am going to try ack or a different version of Vesc hardware
Thatās a lot of motor, for not a lot of esc
Wowā¦ that explains a lot, thanks, I am changing firmware
