Halbj613
November 13, 2019, 6:35pm
#6345
@esk8manbabes I tried checking the wires they are fine and all in the right positions
I tried changing between slave and master vesc but that did not help the vesc tool still did not recognise a canbus connection
I am going to change and go down the split ppm route but thanks for your help everybody
You’ve made Brian a happy man.
b264
November 13, 2019, 7:25pm
#6348
I would just use two receivers, but even Split PWM (“PPM”) I would use over CANBUS though it’s marginal. I like when the only connection between the two is the battery.
Also
xsynatic
November 13, 2019, 8:15pm
#6349
I learned it as PPM and thats why i still use it.
Halbj613
November 13, 2019, 9:12pm
#6350
How would you link multiple receivers to a single mini remote
kook
November 13, 2019, 9:20pm
#6351
simply bind 2 receivers to the same remote
Halbj613
November 13, 2019, 9:31pm
#6352
Is at actually possible
Never seen that do you have to bind both at once or one after the other
drone001
November 13, 2019, 9:34pm
#6353
how long should a battery sit and can i discharge with out hooking the balance plug into the balance charger/dis-charge?.
Not sure if this is a “true” noob question but -
What’s the general opinion on the Flipsky dual 6.6 plus?
Do I need vesc4 or vesc6 for the vx2 pro to be compatible with the unity?
Halbj613
November 13, 2019, 10:20pm
#6357
Gotcha thanks for the help
What do you think is better multiple receivers or split ppm
You’ve been around too long to ask Brian this question. Come on, man!
b264
November 13, 2019, 10:25pm
#6359
I’m not allowed to answer that question.
However, indisputable facts are that my last dual build had 2 receivers in it.
I can’t discuss why, or which I think is better.
Halbj613
November 13, 2019, 10:31pm
#6360
I will take your word for it
I am waiting to receive some connectors for split ppm and for single
Once I receive I will see which works better and base it all on that
I already have two receivers and bind plugs so good there
Kellag
November 13, 2019, 11:32pm
#6361
Wow so well behaved brian
Flasher
November 13, 2019, 11:43pm
#6362
On the contrary of some sparkly princesses
Flasher
November 13, 2019, 11:45pm
#6364
So am I but I’m a bitch with a charger…
