to be honest, every time proffesor replies to me i sigh. Because i spend hours of stupid reserch on here and sometimes i just need a quick answer and WHACK
Edit
No offense @professor_shartsis
none taken. if you think the chart is complicated, hereās the math behind itā¦
Now i am offended
Nah i would not call it complicated, itās just when i am tired reading a graph is not the easiest with so many examples.
Please do continue answering my questions! they are very helpful
what are these things called? DC Jack port?
Iām trying to search for some in the UK - bonus points if you know a good source
Gold star for you
Make sure your charger port size matches and dont go over 4 amps for the 5.5x2.1mm dc ports.
I was wondering what you guys think about this kit: by Torqueboards. I was wondering how it stacks up by price vs normal diy.
Itās good and TB is a well known vendor. However you could get pieces and bits from here & there which might bring down the price.
I need to epoxy some inserts to the holes in my Holypro trampa deck and want some guidance.
Iām thinking J-B Weld 50112, is it good stuff? Seems like a nice clean and easy way to apply epoxy. Should I also lightly sand the inner edges of the deck holes and the outer surface of the plastic inserts? The deck holes already have a lightly roughed surface from the machining process so I might not need to but Iām considering sanding the abs inserts.
Also Iām predicting I wonāt do a great job and will have some overflow. Planning on just wiping the excess off and then sanding whatever hardens. Seem like a plan?
I have everything for my build and forgot the main part that will give the thing life⦠a charger xD
Whats the best 12s 4a chargers for my 12s4p 30q battery pack
i live in Australia so the correct wall plug would be lovely
You need a charger with a fan to keep it cool, check a model which is not too noisy and if you got space at home, aluminum case (runs cooler).
I have FSESC for Sale if youāre in Europe.
Suspension Trucks, like the Baja Boards. Like where can I buy something like that ? I check AliExpress but is nothing like that. Didnāt know if I should start a thread on how itās made so thatās why I asked here before taking room
something like this?
Oh thats good how much are you selling it for?
Working on finishing up my battery pack and I wanna hook it to a charger to charge a little then put it back to storage level. Itās a 12s4p Samsung 30q pack, with a bestech d140 bms, I have it wired in and an xt60 coming off of the leads. Havenāt fully settled on the charger/charge port yet, but being in the rc hobby I have a couple chargers already and wanted to see if I could use one to test my battery before buying more lol I know my isdt q6 wonāt charge it, but I have a turnigy accucel 6 that I think might be able do the job. note Iāve only used lipos in the past Being I donāt have a balance lead coming off I wanted to know if I hook it to the NiMH/NiCd setting could I charge my pack? It shows it does up to 15s so should be good there, just not sure about the settings.
Can someone make a show me your memes thread?
110 Euro actually
Already exists
