moon
September 2, 2019, 12:17pm
3107
This board started its life as an eskating Dual Beast. Generally I was happy with it apart from a few issues however a few weeks ago I tried an Evolve board with pneumatics and upgraded battery. The performance was unimpressive but the ride on the...
Reading time: 2 mins 🕑
Likes: 78 ❤
I really don’t know how much offroading you want to do but @taz ’s evo board should be good for shitty roads. A Hummie deck is quite versatile and has good enclosure options.
[image]
Ahhh my second build, I can hardly believe I’m finally a multiple boards guy. Now I feel like I’m cheating on whichever deck I’m not riding. Great.
I present to you, THE CIRCUIT BOARD
Deck
Hummie with CF bottom and @sender hand love
Deck - $130, @sender treatment - $200
Trucks
Surfrodz 200mm RKP 50/35 split using @mikenyc adjustable baseplates
SZ - $100, adjustable baseplates - $170
Wheels
@haggyboard.timo Bergmeister Blues
[IMG_20190307_150558_1551992894638]
Individually the components used in the build are for the most part common. With @Sender ’s skin work and @moon ’s gear drive combined with SUrf Rodz TKP’s, Psychotiller 6 Shooters, massive 10s6p battery pack all on a LaCroix deck it’s a new level of awesome.
A little history, in a short time…
I like Dragons, always have. If I was a Dragon I would definitely burn cities and have a massive gold horde, so yeah.
The beginning of this design process was to bu…
So got the 4 lipos in to try the board out, mainly to see if I wanted to dump 4-800 in a battery hahaha. Just did a test run and it was good! Going to put the dampeners back in and double check everything is tight and give it another go. Tried taking it up to some speed and it had some bad shakes around 20mph then had two springs pop loose. So that was the test ride leaving it how it came. If the blue are to stiff I have a set of yellows to try So far though I’m thinking that a proper bat…
