As most of you know by now. Sidewinder was involved in an unfortunate accident and has since been decommissioned. Therefore, it’s time to build a new race board… although much sooner than expected.
Introducing… Archangel, named after the Lockheed A-12 project which was the CIA’s slightly smaller and faster version of the SR-71 Blackbird.
Anyways enough of that, back to the build.
@Dsk8 put his Semendeed deck up for sale at the perfect time for me to snag it for the build and it arrived at @Skyart’s shop 2 weeks ago. The original plan was to do an 18/4 pack of the eve 40pl’s so all the electronics could be mounted in the enclosure.
Instead, I ended up buying @JeffyJ’s esk8con pack and am working on a center mount top box with @Tasventouras for the solos that’ll be easy to remove (if needed) for shipping the board.
Gonna go with 205kv 6465(front) and 6495(rear) motors for this build. Should allow me to max out the v2’s on the track if needed.
I want to give @Titoxd1000’s Duality trucks a try on this build after seeing how well they’ve been performing with @tuckjohn and @Dinnye.
I just received my custom motor mounts to run open gears from @IDEA and they look amazing as always.
Sidewinder’s short rod 3links are in storage which I can revert to should I be unable to tune the Duality’s in time for esk8con. Also gonna attempt to run the brp’s on these trucks, (should work) but if it doesn’t, I’ll be going back to the Linns.
That’s all the updates I have on the build right now. I’ll have plenty more in the coming weeks.
