If you have the correct tip angle then they’ll be great.
3 link and channels are made for completely different tip geometry from each other.
The tip angles look a little shallow?
Angled risers could help you out though.
I have a ChooChoo deck that may well end up with airs on at some point.
And what about Trampa Gear Drive? Its clamp and bash guard systems are great.
Unfortunately I believe all their newer drive systems use a 19mm hanger profile so can’t be fitted without some serious modification to either drive or hanger. It is possible, I have seen airs with OBD, but it’s not an option we recommend.
I just slapped some 3ds gear drives on a set. But that’s going to depend on which production you got since they changed their hanger profile.
Out of the gate about a half turn down on medium and stiff setups they feel pretty good. Real carvy for me
So far they feel real carvy yet stable. I think having the added 5 degree wedge would help as well.
For such a boat of a deck that the flex is these make the board feel very nimble to me as far as how sharp you can make a turn/carve. This is coming from riding the riptide hypertruck bushings a week before
Love riding them with soft bushings. Makes the deck feel like it’s got flex, but it’s just the bushings. Very comfy ride!
What bushing setup have you got bud? Yeah the 5 degree wedges give you even more turn, you can print them yourself - the file is on our website!
Off the top of my head I don’t know the duros. It’s the medium setup from your intial setup and stiff in the back. I’ve got a rip tide kit in green and the dark red. Im sure I’ll be trying to dial it in with different shapes and duros to get a feel.
Right now seeing what I’m comfortable with the existing bushings to see if I need to swap out
Stiff is bloody stiff.
What 3D Gear Drive did you say mounts up?
That’s going to depend on your hanger profile of gear drives. Both sets of my fb320 have the eco mini AT v2 that measured 22mm for my hanger. There is a production change where some are 24mm
Maybe it’s just me, but I can’t see the vid
Prolly a format issue. Maybe you’re on Android?
To give you a basic description: the clip is smooth. The deck is responsive.
No, its because people keep posting videos in the HEVC codec and chrome won’t even play it
Default in iOS then. Let me see if I can swap that. Or just link my Instagram since everything is usually there next time.
Yeah it helps with recording the high resolution but at lower resolutions the standard is fine
Thanks for the information!
I just got my air truck today, mad fast shipping holy shit. As expected the axle is larger than I thought. Is there a way I could install a smaller axle, or should I just get some 10id(right?) bearings? I want to run it with street style wheels. If that doesn’t work its ok im actively transitioning to pneumies, i just wanna throw this thing on something already x)
