Hey everyone,
after reading the build thread of @jack.luis and his awesome machine, I noticed that I’ve never showed you my personal Mountain Bomber.
Since I never really was in to off road stuff, it was a late decision for me to get an MTB. But I do like the connection with the board through the bindings and the improved caving ability especially on tight karting tracks.
So I had a slightly different approach concepting the Alpine board.
- Weight of under 20kg
- Speed of 65+ km/h
- Enough torque to shred through all hills and steep bridges.
- Smooth carving abilities and tight turning radius
- Range of 50+ km on pneumatics
- Water proof
- It should be somehow special/different with a cool look
So, I started to order the basic stuff to get a first impression where I could improve or change something.
My starter pack contained:
MBS DW II deck
MBS hubs + 8" wheels
MBS Metal Matrix II
MBS binding and heel straps
Having now a complete non e MTB it was about time to dive into the interesting and juicy stuff
First thing was the decision of the drive train. Since I made some good experiences with Kevin from @Boardnamics in the development process of the Titan board, I decided to use his metal on metal helical AT GD with his 6384 170KV motors.
To get enough power of those babies it was clear that I will need a decent battery with potent controllers. After having some bad experiences with Trampa’s 100V/250A VESC and some good experiences with MakerX Go FOC 12S VESCs I was keen enough to try their 20S VESCs as well. To max out the controllers I went with 42A Molicels in a 20S4P configuration. The VESCs are capable of 200pA continuous or 250pA max each and the battery can provide 140A continuous or 280A max. At 72V it results in over 10kW nominal power or in 23kW max power at 84V. This makes it to my most powerful board by far.
The battery is combined with a 20S Daly smart BMS and the VESCs with Metr Pro. Additionally I’m using a FS 20S 300A ASS and the VX2 Pro.
The electronics box is a water proof all in one box with a cable management plug. You can easily unplug the motor wires and unscrew the box to separate it from the board. All in all the electronics box weighs about 7kg.
Things left to do is to install a telemetry display on top of the box and to gain some space between the GD and the deck for max lean.
Part list:
MBS DW II deck
MBS Metal Matrix II
MBS bindings and heel straps
Boardnamics drivetrain metal/metal helical AT GD with 6384 170kV motors
DIY 20S4P Molicel 42A battery
Daly 20S smart BMS with phone APP
FS ASS 20S 300A
FS VX2 Pro RC
MakerX 20S 250A VESCs
Metr Pro
Water proof MFH box with cable management
*Telemetry display
More pics/vids and a review are coming after the weather gets better in Germany.
