frame
1
u guys know the drill, same old meepo 165mm cyclone racing tire set, 65mm wide
if u PM me, put ur name and meepo tire in the subject
You can also contact me via
Telegram: Contact @frame_b022
each set is 4 tires + 4 tubes
100USD shipped worldwide
with the exception of polar bear and penguin land, as well as Ukraine / Russia and a few uncommon countries, PM if unsure
Wheel hub tested:
Meepo cyclone hub = obviously they work
Trampa megastar / superstar / sunmate = u 100% need wheel hub spacer
Trampa phatlads = 100% NO unless u spacer it or trim the bead, 100% untested on that
Newbee m1 hub = yes, there is YT video showing they work
infinityhubs = yes, but it takes some muscle to get it on, click to see it mounted
Boardnamics Group GT3 (aka Kevball) = yes, click to see it mounted
Raijin Racing EVO RX-3V = yes, click to see it mounted
Land-Surf Excell RS1 = yes, click to see it mounted
Wheel hub not yet tested:
Trampa hypa / primo / deepdish
MBS rockstar / fivestar
Evolve
Newbee pentagram / impaler
frame
2
small amount of bulk order also available, will do any type of packaging arrangement to get around regulations / import restrictions
Will these fit on sixshooters?
Nacho
7
I don’t think so aren’t six shooters 6x2 or 6x3
frame
8
Can’t tell unless I have the hub dimensions
Plurf
10
Interested too, if they fit rockstar 2 I’m interested
Any idea if these’ll fit 3dsas 3.75"?
frame
12
34mm wide is too narrow these tires unless u can make a spacer for it
frame
13
u have the wheel hub dimension?
rusins
14
I’m pretty sure they’re just as wide as Rockstar 2s are, so the answer would be no
I was afraid of this… got no more axle length so guess it’s a no go with some spacer as well. thanks dude
sorry @frame I don’t unfortunately. Not any more dims than 3.75" that is lol
I could deflate a wheel tomorrow and check if you’re interested though
frame
18
the tire should fit most 3.75 wheel hub, but its the width that limits if u can use the tires
I put a qind 200x75 fattie on an evolve hub for science last night
