50mph razor scooter build using esk8 parts
So far I have the following:
  • This Pocketmod Razor Scooter I got for free from work
    It has a very solid welded frame. I forgot to take pics but I will edit them in when I get home from work.
Edit: Here is the frame
  • This massive 170KV motor I got for very very cheap
  • 120 of these LG cells to make a 12s10p
    I chose these instead of more WH because I want to be able to throw a fuckton of current. I can always add more capacity later if I need to.
  • A 13T sprocket.
  • A xenith to run this big motor in super single mode
Whats Left to get
  • An L-Shaped motor mount. I will make this myself.
This is stoked
Holy shit
Can we get a pic of an adult human sitting on one of these?
We need this. I have a 6 year old girl on my street that cruises a pink one of these, most often in an Elsa dress.
this is me on it. I’m 5’10" for scale
She must have an even smaller version then. Yours looks much bigger.
There’s an old dude that is a retired physician that has one in my new neighborhood. He cruises around and is probably the only one that doesn’t want the cops to come get me.
Thats what she said
It felt right just typing it. There was no eject option.
And, to be clear, you want to go 50mph on this? Dibs on all your stuff :joy:
don’t try to seperate them, trust me.
omg
How are the brakes on this thing :joy:
NO
well maybe in a big open road with no cars a bunch of armor on
really really solid actually. They only exist on the rear tho.
So I should leave them as 2P modules and go from there?
yep that works, but since you can’t reconfigure from there I don’t see why you should take them apart at all.
I wonder if it would be possible/practical to wire a position sensor onto the brake lever.
When you pull the brake it gives a mechanical input to the actual brake, and an electrical input to the esc to start regen braking.
Basically find a balance so it’s a 50/50 electrical/mechanical split. (Or any combination)
That way you reduce wear on the mechanical brake, and get some regen to your battery.
Although I suspect this would also need custom firmware so probably not very practical haha
I thought about this. It’s too much work just to get regen on this meme build. The regular cable brake works great. The left handlebar has the brakes and the right has the throttle. EZPZ
To make them fit in the OEM battery compartment
yeah that makes sense. They can be split in half instead of fully down to the 2S2P groups and kept inside their plastic after it is cut. I think I made a CAD model of these 2S2P bricks actually one sec.
hp2s2p zip.zip (616.3 KB)
This motor eats controllers for breakfest. They love amps btw.
