Yep I have them. Sent you the invitation
Cheers, thanks.
Do you have any left or planning another group buy don’t need right away but definitely need a set
pm coming
just for information, still have few sets left of the RKP Hammock in case someone wants one immidiately. Both raw and matte black.
For the moment I am testing the TKP adapter and so far so good
Filled out the form - a little late, I know. However if there is a set left, I would be happy to try them. Thanks a lot.
Hi. Do you mean the RKP hammock? For caliber, Paris ecc…? Yep I still have a set of both raw and black
Yes, these adjustable base plates. If could ship a black one, I would be most happy.
They are compatible with both Kahua and TB’s DD truck, right?
Kahua yes, TB 218mm trucks yes. The direct drive no because they have slightly different kingpin - pivot distance than original caliber, Paris truck styles.
Great! I would try them on the Kahuas then. They don’t work with MBS Matrix II trucks or do they?
If you mean the mountain board style no. Totally another base plate style. I made Hammock to replace those that are limited in choice and be able to use mountain decks with other trucks without raisers.
Kahua you can see it here
Yes, those MTB trucks depicted above, exactly.
Hello !
I got a second hand, never ridden set of Hammock BP. But the part with the kingpin keeps moving (see video below), is it normal ?
the clearance is there to allows sliding. Torque it down
Spread the bolts as much as possible between the holes. Then torque the bolts to lock it and then proceed half turn more until you fill up the gap.
It went well, thank you
I guess I was afraid to torque to much !
no no they are made for that
@rey8801 Are you planning on doing another group buy in the near future?
There is one running right now. Took longer due to the virus situation. Parts should finally be shipped to me next week. I will probably have some sets left. You can fill up the latest Google form of you want one ![]()
Just in case
This GB involves SR TKP too
Pretty interested, but will be looking to use them for street luge.
What range of angle does the baseplate offer?
I use mine on thane mostly. Base plate goes from 0 to about 70-75. The top end is just above of what you actually need
Welcome on the forum
