esk8.news esk8 calc donate now
3DServisas Products
Hi, guys instead of creating multiple topics for each product we decided to make one central topic for all products.
Gear Drives
FatBoy SS Mini Gear Drive V4 for FatBoy 240/260 Trucks
FatBoy SS Mini Gear Drive for FatBoy 240/260 Trucks. This version is all milled gears in-house using outer-gear style gearing with much higher tooth size for hardcore power delivery. This kit does not require any alteration to the hanger.
New all aluminium EN AW-6082-T651 gear drive with aluminium /plastic gears, V-ring and other improvements.
This is a pre-assembled gear drive for ease of use and possibility to ride as soon as possible!
Comes with pre-set gear meshing and initial angle (15 deg, front side). Angle can be changed before putting this setup on the deck, (6 total positions).
Angle adjustment is not threadlocked. It is not necessary, but recommended to use a bit of threadlocker after setting up wanted angle.
Every other drive train screw is initially threadlocked.
All bearings are pressed in using a thermal press method, not press-fit, especially not foot press-fit.
All bearings are pressed into Aluminium.
Bearing differences:
  • Straight cut gear drives use groove ball bearings.
  • Helical gear drives use angular contact ball bearings to sustain the axial loads.
Gear types and materials:
  • Wheel gear is machined from plastic (harder than POM, equivalent to aluminium hardness).
  • Wheel adapter is aluminium.
  • For straight-cut gears: motor gear is aluminium.
  • For helical gears: motor gear is steel.
The kit comes with custom CNC machined wheel hubs with a negative offset to make them fit on normal longboard trucks. Other wheel hubs do not work as these also have a special mounting plate which reduces total width of the drivetrain.
Tyre Compatibility:
3.75" 125mm Gummies, 6.5", 7", 8" from Trampa/MBS tires and some other tires like 200x50
2.9" Nylon 6x2 Tires from AliExpress
Bergmeister Bergmeister tires 5,7x1,7
Motor Compatibility:
FatBoy 240 6350, 6355, 6360, 6365, 6374
FatBoy 260 6350, 6355, 6360, 6365, 6374, 6380, 6384, 6396
Types:
Gear Type Gear Ratio Motor Axis
Straight 1:3 8mm
Straight 1:2.6 8mm
Straight 1:3 10mm
Straight 1:2.6 10mm
Helical 1:3 8mm
Helical 1:2.6 8mm
Helical 1:3 10mm
Helical 1:2.6 10mm
Using Maytech motors or other motors with axle length <=25mm doesn’t require cutting off the motor shaft!
Easy steps to assemble:
  • Add thread lock (Loctite 648) on the motor shaft, insert the key into the keyway slot.
  • Push the motor shaft with the key into the drive gear, screw the motor to the mount.
  • Liberally add the provided grease after everything has cured.
  • Close the gear drive.
  • Mount it on the baseplate.
  • Ride and enjoy!
Pre-Assembled Kit Contains:
  • 2 x Motor spur gear (for 10mm/8mm shaft)
  • 2 x Wheel Gears
  • 2 x Hanger mount adapters
  • 2 x Baseplates with the motor mount holes
  • 2 x Gearbox Aluminium covers
  • 2 x V-Ring
  • 4 x FatBoy Solid Core Hub with custom ET made for this kit
  • Screw kit
  • Gear lubrication
  • 2 x FatBoy 240/260 Hanger (Compatible with Caliber II Baseplate or our adjustable baseplate which you can purchase from here)
Whole gear drive weighs 2000g.
Wheel hubs come anodised in black!
Motor and tires are not included in the kit!
After purchase will be shipped within a 3 week period
Price: from €460.00 + VAT (where required) + Shipping
FatBoy Mini Urethane Gear Drive V4 with FatBoy Hanger
FatBoy Mini Urethane Gear Drive for ABEC wheels or Kegel wheels for FatBoy 240/260/275 Hanger which fits FatBoy / Caliber II Baseplate.
Angle adjustment is not thread locked. It is not necessary, but recommended to use a bit of thread locker after setting up wanted angle.
Every other drive train screw is initially thread locked.
  • Wheel core adapter is aluminium.
FatBoy 275 6350, 6355, 6360, 6365, 6374, 6380, 6384, 6396
Types:
Straight 1:2.4 8mm
Straight 1:2.4 10mm
Straight 1:2.6 8mm
Helical 1:2.4 8mm
Helical 1:2.4 10mm
Helical 1:2.6 8mm
  • Add thread lock on the motor shaft, insert the key into the keyway slot.
  • Push the motor shaft with the key into the drive gear, fasten the motor to the mounting plate.
  • Ride and enjoy!
Pre-assembled Kit Contains:
  • 2 x Motor spur straight or helical gear (for 10mm/8mm shaft)
  • 2 x Wheel Hubs with straight or helical gear
  • 2 x Kegel/ABEC wheel hub mounts
  • 2 x Aluminium Gearbox covers
  • 2 x FatBoy 240/260/275 Hanger (Compatible with Caliber II Baseplate or our adjustable baseplate which you can purchase from here)
  • Screw kit
  • Gear lubrication
Motor and wheels are not included in the kit!
Price: from €440.00 + VAT (where required) + Shipping
FatBoy SS Drive HD
FatBoy SS Drive HD for MBS Metal Matrix II Trusk and Trampa Vertigo - Infinity ATB Truck - the new HD gear drive from 3DServisas featuring thick gears and reinforced design new materials Aluminium EN AW-6082-T651 and better efficiency and durability of the gear system.
Features
  • Out of the box support for 63mm motors .
  • Aluminium reinforced wheel spur gear, a lot sturdier truck mounting system.
  • New Black colour casing from a new material which his highly durable scratch and impact resistant with sound dampening properties
  • New lubrication system which utilizes small volume inside gear drive which allows more efficient lubricant usage
  • The motor spur gear is now locked with a keyway which stops all gear slippage on the motor shaft.
  • Laser Cut Stainless Steel protection plate for smooth v-ring operation.
  • Ultra Slim Design with a total height of 119mm (4.69")
  • No modifications required for the trucks plug and play.
  • MBS trucks - Maximum motor size: 63mm diameter and 84mm length.
  • Trampa trucks - Maximum motor size: 63mm diameter and 100mm length.
Kit Contains
  • 2 x Baseplates
  • 2 x Hanger mount adapters (Three positions -15º, 0º, +15º)
  • 2 x Black Gear Drive Covers
  • 2 x Aluminium Motor Spur Gears
  • 2 x Wheel Spur Gears
  • 2 x Wheel Spur Gear Reinforcement plates
  • 2 x Wheel Mount Plates (Trampa SuperStar / FatBoy Solid Core Hubs)
  • 2 x Stainless steel protection plates
  • 2 x V-Rings
  • Screws and Accessories
  • Gear lubrication
Assembly Guide
Whole kit weights 1480g.
Price: from €299.00 + VAT (where required) + Shipping
FatBoy SS Drive - Heavy Duty Gear Drive
FatBoy SS Drive for Trampa Vertigo - Infinity ATB Truck - the new heavy duty gear drive from 3DServisas featuring thick gears and reinforced design new materials Aluminium EN AW-6082-T651 and better efficiency and durability of the gear system.
Features
  • Out of the box support for 63mm and 80mm (including 80100) motors featuring new rail-based gear mesh adjustability system.
  • New RED or Black colour casing from a new material which his highly durable scratch and impact resistant with sound dampening properties
Kit Contains
  • 2 x Baseplates
  • 2 x Motor Mount Plates
  • 2 x RED or Black Gear Drive Covers
  • 2 x Aluminum Motor Spur Gears
  • 2 x Laser Cut Stainless steel protection plates
  • 2 x V-Rings
  • Gear lubrication
Assembly Guide
Price: from €400.00 + VAT (where required) + Shipping
Trucks
FatBoy Solid CNC Machined Hanger
A fully CNC machined Aluminium EN AW-6082-T651 FatBoy 230/240/260 Hanger for Caliber II Baseplate and 260 for heXL Baseplate with titanium 8mm diameter length 51mm axles. Compatible with FatBoy gear drives.
FatBoy Hanger weights 300 g.
Hanger profile dimension :
Height - 19,70mm , Width - 18,10mm , Radius 3,00mm .
Sizes:
Width Fits
230 FatBoy Adjustable Baseplate / Caliber II Baseplate
240 FatBoy Adjustable Baseplate / Caliber II Baseplate
260 FatBoy Adjustable Baseplate / Caliber II Baseplate
260 heXL raw heXL Baseplate
The price is for ONE hanger only !
After purchase will be shipped within a 1-2 week period
Price: from €60.00 + VAT (where required) + Shipping
A fully CNC machined Aluminium AW-6082-T6 FatBoy adjustable angle 35-55° baseplate. Fits: FatBoy 230, 240, 260, 275 hangers and Caliber II Hangers
Includes:
  • 1 x FatBoy Adjustable Baseplate
  • 1 x RipTide WFB Pivot Cups 96a
  • 2 x RipTide KranK Barrel Bushings 90a
  • 1 x Large Cup Washers
  • 1 x Stainless Steel Washers, Small
  • 1 x Kingpin Zinc Yellow-Chromate Plated Hex Head Screw, Grade 8 Steel, 3/8"-24 Thread, 2-1/2" Long
  • 1 x High-Strength Steel Thin Nylon-Insert Locknut, Grade 8, Zinc Yellow-Chromate Plated, 3/8"-24
FatBoy BasePlate weights 290 g.
After purchase will be shipped within a 2-3 week period
Price: from €64.00 + VAT (where required) + Shipping
FatBoy X LCD Plate Longboard Trucks Braket with Battery Monitoring LCD
A 3D CNC Machined Aluminium EN AW-6082-T651 FatBoy X Plate a longboard truck bracket with battery monitoring LCD screen.
Specifications:
  • Waterproof
  • Up to 15S Li-ion Battery capacity meter programable
Includes:
  • 1 x Bracket with LCD
Price: from €50.00 + VAT (where required) + Shipping
FatBoy X Plate Longboard Trucks Braket
CNC machined Aluminium EN AW-6082-T651 FatBoy X and bracket for long truck.Height is 6mm (0.24")
Colors:
  • Black
  • Red
Includes:
  • 2 x Bracket
Price: from €15.00 + VAT (where required) + Shipping
FatBoy 35 Solid Riser adapter for Trampa, MBS, Longboard trucks
A FatBoy 35º Solid Riser adapter of Aluminium 6082-T6 for mounting mountain board trucks to normal longboard decks.
Includes:
  • 2 x FatBoy 35º Solid Riser adapter
Works with:
  • Trampa Trucks
  • MBS Trucks
  • Longboard Trucks (New / Old School)
Price: from €120.00 + VAT (where required) + Shipping
Belt Pulleys
FatBoy Wheel Pulley Set for ABEC or KEGEL 44T, 42T, 40T, 36T, 32T
FatBoy Wheel Pulley set, for Abec or Kegel wheel hub. CNC machined Aluminium EN AW-6082-T6 with bearing spacer. Available in multiple tooth count.
Includes:
  • 2 x FatBoy Wheel Pulleys Width 9 mm, 15 mm
  • 2 x FatBoy Adapter for Abec or Kegel
  • 2 x Bearings 608
  • 2x Bearing Spacers Length 3mm
Works with:
  • 80mm - 110mm Wheels
Compatible Hangers:
  • Torqueboards 218mm hanger
  • FatBoy 230mm 260mm hanger
  • Surf-Rodz RKP hangers
  • Surf-Rodz with long axle hangers
  • Evolve Hanger (will require 10mm bearing replacement)
  • Other hangers with minimum 40mm axle length and maximum 28mm hanger thickness.
Options:
Style Width Tooth Count
Kegel 9mm 36
Kegel Reversed 9mm 36
Abec 9mm 36
Kegel 15mm 32
Kegel Reversed 15mm 32
Abec 15mm 32
Kegel 15mm 36
Kegel Reversed 15mm 36
Abec 15mm 36
Kegel 15mm 40
Kegel Reversed 15mm 40
Abec 15mm 40
Kegel 15mm 42
Kegel Reversed 15mm 42
Abec 15mm 42
Kegel 15mm 44
Kegel Reversed 15mm 44
Abec 15mm 44
Info:
  • (Kegel reversed) pins are 5.6mm⌀ x 19.5mm
  • (Kegel) pins are 5.45 - 5.5mm⌀ x 19.5mm
Also available as only pulley side only or only wheel adapter
Price: from €65.00 + VAT (where required) + Shipping
Wheel hubs
FatBoy Solid Core 3.75" Hub 5 Spoke (set of 4 hubs)
FatBoy 5 spoke Solid Core Hub 3.75" diameter for the 28mm bearing. Precision CNC machined from two pieces of aluminium, these wheel hubs provide accuracy and rigidity for the harshest road or trail conditions.
Solid Core hubs are compatible with all 6.5", 7", 8" tires in the market, fits our InnerGear and MiniGear drivetrains and other drivetrains in the market which fit 5 spoke design.
The Solid Core hubs was born for rugged environments. That’s not to say it enjoys the abuse, but it does mean that it’s designed to handle bumps, ruts, rocks, steeps, sand and the other kinds of terrain Moab throws at you. Solid Core hubs are produced using CNC milling machine from a solid hunk of extruded aluminium that has been T651 Heat treated (Aerospace-grade quality) all of which is constructed & connected together using marine grade stainless steel nuts & bolts which lets to provide absolute precision and rigidness for those bumpy roads.
Compatible with:
  • 28mm x 8mm size bearings (Trampa 12mm, 9.525mm axles)
  • 22mm x 7mm size bearings (8mm and 10mm axles)
Wheel hubs compatible with Trampa Superstar compatible Gear Drives and Pulleys
Weight: 290g single wheel hub
Kit Contains:
  • 8 x FatBoy Solid Core Wheel Hub pieces
  • Screw kit
Price: from €165.00 + VAT (where required) + Shipping
FatBoy Solid Core Hub 4.65" For 9" Wheels 5 Spoke (set of 4 hubs)
FatBoy 5 spoke Solid Core Hub 4.65" diameter for the 28mm bearing. Precision CNC machined from two pieces of aluminium, these wheel hubs provide accuracy and rigidity for the harshest road or trail conditions.
Solid Core hubs are compatible with all 9" tires with 100mm inner diameter and 42mm width in the market, fits our FatBoy SS and FatBoy Mini Trampa drivetrains and other drivetrains in the market which fit 5 spoke design.
Compatible with:
  • 9" Tires with a 100mm inner diameter and 42mm width
  • Wheel hubs compatible with Trampa Superstar compatible Gear Drives and Pulleys
Weight: 490g single wheel hub
Kit Contains:
  • Screw kit
Price: from €175.00 + VAT (where required) + Shipping
Cases
Mountain board Case for VESC6, Focbox Unity, Old Focbox
CNC machined aluminium - plastic case for VESC6, Focbox Unity, Old Focbox speed controller. The case provides more efficient heat spreading and protects from water and dirt.
Features:
* The case has pre-drilled holes in the base plate for mounting to the board Unity , 4.12 based FocBox , Vesc 6 .
* 2 x Three-single wire holes for motor outputs with cable glands, spiral
* 2 x Wires for power input with cable glands, spiral
* 2 x Wires for motor sensor input with cable glands, spiral
* 2 x Seal silicone cord
* Heat spreading fins for increased cooling capacity.
* 170mm (6,69") x 120mm (4,72") x 43mm (1.69") and weighs 760g (1,67lb)
* 153mm (6,02") x 103mm (4,05") x 30mm (1.18") Internal dimensions
Includes:
  • 2 ps. Aluminium plates
  • 1 ps. Plastic frame
  • 10 ps. Cable glands, spiral
  • 2 ps. Silicone cords
  • 4 ps. Unity Screw kit
  • 10 ps. Box Screw kit
  • Thermal Conductive Silicone paste
Price: from €75.00 + VAT (where required) + Shipping
FocBox Unity Heatsink Plate
CNC machined aluminium heatsink plate for FocBox Unity speed controller. The heatsink panel provides more efficient heat spreading and integration into your enclosure. No need to disassemble Unity.
Features*:
  • The plate has lip & holes for mounting into cutout hole inside the enclosure
  • Machined from 6082T6 Aluminium
  • Heat spreading fins for increased cooling capacity.
  • Whole size: 130mm (5.11") x 80mm (3.15") x 11mm (0,43")
  • Heatsink size: 112mm (4,40") x 62,5mm (2.46") x 7mm (0.27")
  • Weighs 210g
Includes:
  • 1 pc. Aluminium heatsink plate
  • 10 pc. Stainless steel screws M3x10
Price: from €45.00 + VAT (where required) + Shipping
FocBox Unity Mount plate
CNC machined aluminium mount plate for FocBox Unity speed controller.
Features:
  • Machined from 6082 Aluminium
  • Mount plate size: 137mm (5,40") x 50mm (1,97") x 3mm (0.11")
  • Weighs 50g
Includes:
  • 1 pc. Aluminium mount plate
  • 4 pc. Screws M3x6
  • 4 pc. Self-tapping screw M4x12
DieBieMS Heatsink Plate
CNC machined aluminium heatsink plate for DieBieMS controller. The heatsink panel provides more efficient heat spreading and integration into your enclosure.
  • Heatsink size: 140mm (5,11") x 60mm (2.36") x 10mm (0.39")
  • Full height 24mm (0.94")
  • Weighs 135g
Includes:
  • 4 pc. Stainless steel screws M3x10
Price: from €30.00 + VAT (where required) + Shipping
Electronics
FatBoy Mini Sparky Switch Ver-2 100A-200A 100V Pre-Charged Anti-Spark Switch with Push To Start
FatBoy Mini Sparky Switch with pre-charging circuit and push to start capabilities. Designed for high load switching capabilities. Comes with DIY version (just module and button) or KIT version (with module, xt90 connectors soldered and wired button). This module comes with CNC machined heatsink for dissipating heat generated by switching devices.
Features:
  • Turn on by pressing button (or if PTS enabled pushing your board)
  • Turn off by holding a button for 2 sec
  • Hardware inrush current limit pre-charging circuit (supports big capacitor banks on ESC)
  • Turn on melody
  • Enable/Disable PTS
  • High Side Power Switching (Switches Positive wire)
  • Current capabilities in 3 stages 100A, 150A, 200A
  • Panel mounted push button with blue LED
Includes (DIY Version)
  • FatBoy Mini Sparky Switch PCB
  • Heatsink
  • Thermal Pads
  • Screws
  • Panel Mounted push button with blue LED
  • 150K Ohm Resistor for Push Button LED
Includes (KIT Version)
  • Heatsink
  • Thermal Pads
  • Screws
  • Wired Panel Mounted push button with blue LED
  • XT90 Input / Output Connectors with wires soldered to PCB
Specifications (Module):
Input Voltage 15V - 80V (PTS enabled) 100V (PTS disabled) 6S - 19S (22S)
Current Rating 100A, 150A, 200A
Dimensions 35mm 1.38" x 58mm 2.28" x 18m 0.7"
Weight 45g (with heatsink) 80g (with wires and connectors)
Specifications (Button):
Total Length 18mm
Required hole diameter 12mm
LED Resistor 150K Ohm
This device should not be used as the main power disconnect from the battery as it itself is consuming power while in the off position to the provide functionality required. Highly recommended to have a mechanical disconnect available in all times in case of emergency.
Summary
If you have any question regarding our products or have suggestions ask in this topic please.
Placeholder 1
Placeholder 2
Placeholder 3
FatBoy 320 MBS Metal Matrix II Hanger
Our new hanger for MBS Metal Matrix II system to be used with MBS Metal Matrix II Baseplate
Specs:
  • Width: 320mm (without axles) 450mm (with axles)
  • Axles Diameter: 12mm Length: 65mm
More information coming soon
All our new gear drives will feature TPU guard which is flexible and scratch resistant:
We still have few FatBoy SR hangers left for sale more information in PM
Important notice for our FatBoy Sparky Switch users:
We highly suggest to route ground signal straight from input connector to output connector and use small wire to provide ground signal to the switch like showed in picture. At higher loads PCB ground plane is experiencing heating up which is not healthy for PCB.
You and moon make the sickest Eskate gear east of NYC. Do a dumb USA tour and I’d easily lose a pay check worth of … euros? Bitcoin? Pachinko balls?
Thanks for kind words it’s all @3DServisas work, I am just making some electronic stuff when I have time and trying to provide support and help. Btw we are from North Europe :smiley: Regarding USA tour maybe in the future, I guess @mackann will come there sooner than us
Loving the new products. What kind of plastic are the gears made out of? Has always been on my mind cus I always thought it was Delrin
I don’t remember exact name difficult scientific name, but i think it’s pretty similar to nylon, but similar to properties of aluminium and, less wear, friction and etc.
Derlin is really brittle and breaks pretty easily.
Timeline on mbs hangers + compatible gear drive??
As far as I know should be available in January, compatible drives I think are SS Drive and HD Drive have to verify it
Y u do dis?
wallet rocks back and forth anxiously
Have been testing the Urethane Helical gear for some time now, its fantastic! Sound great and freerolls very nice. Low wh/ km to
Im not sure, but i think the fatboy mbs hanger is compatible with all your gear drives?
Recorded with mobile cam so not the best video, but it shows the gear in action with 6374 motors
I don’t see a Dual FocBox Case Heatsink Plate on the list… Are you not going to make anymore of these?
