I like trampa hubs because you can customize them and widen them using a 3d printed part.
i got their v4 drives and i believe he still sells spares
is it worth stocking up?
into his housings?
yeah, idk some chance it could work with custom holes drilled or adapters made.
these are your gears
these are the BN AT gears
noice
my drives are v4 helical mini drives
will the at gears accept the mounting pattern for the hubs?
That’s a negative. You need the trampa hub adapter. Then with that there isn’t enough axel length on the FB 275 and lower hangers to accommodate it.
I just went through those questions with 3d servisas via email/dm.
ah however
@ahrav installed it with ofset trampa hubs on the outside and standard fatboy rims on the inside so the axle just makes it and you dont need the adapter
More money than I want I to fork over for hubs at this point I’m time.
yeah def expensive
my drive train alone new is prob around the 2k$ mark
I migh be willing to buy those wheels off your hands if you are in eu?
I’d presume you were looking in a mirror
Still love you even tho you stand upside down
Yes, where are you located.
@Bavioze ok, just saw it, you are from Nederland. I’ve payed 120€ plus shipping from ATBShop and like i said i sell it for half, 60€ plus shipping . The bearings are included. Is that ok for you?
Which bearings?
