Did not want to pull one out in case it was with blue threadlocker
Thanks! Good thing I checked
@RDs you should theadlock yours as well.
Just a reminder that Loctite 290 can be applied AFTER assembly. It’s insanely useful. Just the tiniest bit, way less than a drop. You can “wet” a toothpick with the tip of the nozzle, stick the toothpick in the crack between the bolt and part, then put the tiniest bit of Loctite 290 on the toothpick, and it will run down the toothpick, into the crack, and into the bolt threads. Of an already-assembled part.
on these CNC’d pulleys that didn’t seem like an option
It’s only a few minute job anyway
Never underestimate how runny Loctite really is. Some kinds of it just wick into microscopic gaps like there’s no tomorrow.
That’s all fine and dandy, until it finds a bearing race. That’s why to limit the quantity applied
Was a pretty windy day, but here is a video of finality drives in action. The really high pitched sound you hear is from the motor, when that sounds is not there, you can’t even hear these drives!
Damn bro, she fine.
Really need to get myself a set of those drives.
Is that a regular gear drive setup, or the finality style drive + hubs? ![]()
Since it’s HyperTrucks, it’s definitely a Finality setup.
It is Finality 103mm gear drive, 6.5"-8" rims on Lacroix HyperTrucks. Custom anodized colors (blue for the gear drives and silver for the rims).
looks familiar
Please make these for 3links!!
Please make metric 3 links / NKP trucks LoL
Finality AT Helical Gear Drive , Finality Channel Trucks with Finality Wheel Rims . Custom anodized colors green .
Oh my god no… you can’t do this to me!
Seems like you’re not in luck.
God damnit that’s beautiful
How do barrels compare to something like mbs bushings or hyper truck bushings for just flat out speed?
Say high speed was my ONLY concern on this build… how would barrels compare
Depends on what you consider high speed. I ride at 50km/h (31mph) with the barrels.
