Forgot to upload this when I finished it.
Riser pads for TBDDs with a little cable routing bit.
Thanks for the input.
I’m hoping this could be helpful for someone; shims for a 31.8mm bike light mount on cal II style trucks:
I can drop the files if anyone is interested
That’s the first time I’ve seen a qr-clamp for lights, they look really smart/solid. Mine are all p-type so I’ll have to trial it on something that close to the road. But I’ll take a copy of the files if you’re uploading them.
Hell yeah dude! I’m literally about to start doing this for my matrix trucks on the same lights, the rubber just slips a bit too much.
What outer diameter did you go with?
31.8mm; most bike handlebar accessories are that diameter, or 25. 4 mm (sometimes 26mm)
I’m just glad I have enough clearance for it
Caliber II Bike Light Shim HALF.stl (7.3 KB)
Caliber II Bike Light Shim Smooth Half.stl (6.5 KB)
Caliber II Bike Light Shim.stl (3.6 KB)
I haven’t printed the single piece shim, so ymmv; The halved shims do need some sanding though, and its a tight fit (just so the light can’t slip around)
How much weight can it hold? I need to design me some for 8inch. Might use a similar design to yours
Well my board is quite heavy.
12s7p hummie deck with avio mk2 gear drive. It’s rock solid.
Mind sending me a step or f3d file?
WallMountBergs.stl (178.9 KB) WallMountBerg.step (65.5 KB) WallMountBergs v0.f3d (79.0 KB)
There you go. I’ve printed it with 4 Wall count, and 35% infill
EDIT*** Added a picture so people would know what those files are about.
Will it fit if you shorten the ark? It should still work j guess.
There are other things that would also be too big for my bed like the wall base. I might take a split to it so I can print it and see if it fits. Then head off to a local printfarm. They have a Megalodon sized printer with an 800x800 bed
My eventual plan is to build a Jubilee, with either a 300 or 350mm cube build area. My current printer is a little baby Cetus Mk2 that has had the absolute shit modded out of it.
Get a cr10s. 300x300 print bed, good value printer
I found an ender clone with a 310 x 310 x 400 build size that dipped to $199 for a minute. Dual z axis is a plus.
Going to sell one of my ender 3s and get that bigger Boi.
To all the prusa i3 mk3 users…
Is it worth the price difference upgrading from ender 3 to prusa?
I love my Prusa mks3. It’s my first printer. I have had it for 2 months and had no issues with it whatsoever despite me being a total noob in 3d printing.
I obviously have no other printer to compare to so not sure how much this helps. Plus, I’m Czech so Prusa is an obvious choice.
