Just on grabcad
Search caliber truck😉
I do but I’m not at my pc right now. Will try and remember to upload when I am in a few days.
Nice that would be great!
Anyone has an STL file for the caliber baseplate?
Few post above you probably want the step file or similar. STL sucks for CAD.
Reminder
trampa full length truck : https://a360.co/2zOU4lR
Note: this was made with a pair of calipers and by eye. I think its reasonably accurate however i had to guess some curves that couldn’t be measured. generally dimensions that are added have been measured but you should check any critical dimensions if your designing mounts.
EDIT: oh also i remember that the axel width is not 12mm due to the threaded ends and i was to lazy to fix. just be aware that it should be 12mm.
Thanks, appreciate it! No problem I would have done the same and ill keep it in mind.
evolve rear truck/hanger
Bump !
Asking the same
Please gents, if someone got the hanger of the last-gen. of the Matrix 2 trucks (wider one) or full trucks …
@mishrasubhransu, maybe you have already found your happiness?
(I have sold mine but need the hanger file to finish a little project, even an stl to be able to print the hanger it would be awesome ^^)
Thx a lot !!!
gear drive anyone?
Does anyone have STL files for a Riptide like tunnel riser?
It doesn’t have to be exactly the same design. Anything with some space for routing phase and sensor cables will do. Thanks.
Update: Never mind. I found the search button. https://www.thingiverse.com/thing:3492217
Thanks @taz. Exactly what I needed.
Asking in case I’m lucky
Does anyone have a file for aps remotes?
do you need a new APS remote? I have one
@Lee_Wright Technically no. I just destroyed the bottom of my shell in a small crash this afternoon. All the electronics are still good
If I remember tomorrow I will take mine apart and model something for you. is there a side you need more or both?
Sadly both. That would be awesome. You are wonderful and I thank you
Leave it with me bro
Anyone have STL or step files, specs for genuine ABEC cores?
Friendly reminder
