You can prolly get what you want from this.
I have step file for original ABEC cores, but if you search online you can find the same thing by googling… the 3D model i found works perfectly, GrabCad I think is where I found it, but I can email what I have to you if your google-foo is weak
EDIT… beaten badly by the bearded one…
I dont suppose anyone has a the model of the Switchblade 40’’ lying around, do they? Or even just a deck they can take photos of?
Thanks guys
Second Attempt here.
Anyone have the model of an XT90? Or atleast does someone know the length of the little metal prongs in the back?
What would i do without you <3
Does anyone have a reasonably accurate pattern for a trampa truck clamp? It would save me some time of trial and error to design a clamp.
Clamp?
Think this is reasonably close. also all driven from one sketch so should be easy to make changes if needed
Awesome thanks CAD master
Trampa and/or MBS trucks
Especially the mount holes
Anyone have a drawing or model of the boardnamics 63mm mounts?
I’m planning on designing and printing some nice shrouds for them since I just discovered I have access to a stratasys…
Thanks for that, I just made the base plate and was starting to draw the truck, you saved so much time
I need a 50 tooth wheel pulley with a 17mm surface area that will bolt on to Bergmeister wheels.
I sold 47Ts last year…
