For making covers for those areas of course!
I see. If you still need help with that shape, I can prolly do it - just lmk
I’m all good, got what I need, cheers
Looking for a belt cover / bash guard for the @Boardnamics Caliber II 63mm Motor Mount
Downloads page doesn’t have any 3D files.
this thread has a belt cover for 97mm wheels.
anyone have the hole pattern for the ubox? A whole ubox model would be even better
@BornBoneless ? I saw your Ubox box, great work. Wanna share a screenshot of your bolt dimensions? It’s proven really hard to get dimensions off of your STL I tried
my cad dump thread has a ubox model.
You’re from manhattan? I owe you a beer, you should come out to the group rides.
lol yeah I was thinking about it but I’m just a very solitary person. maybe someday.
Take your time, @worldismine772 and I could meet up with you and keep it small. I want to meet as many members IRL as possible.
just let me know when/where!
i’m also very solitary, but group riding is a surprising amount of fun
Anyone have step files for 8" kenda tyres or simular pattern? Thanks
feeling lazy, so before i draw some up, anyone have +5 deg angle riser for trampa, mtb base plates?
There’s a couple on thingiverse dude., you may have to just chop the shape out and make your own 5 degree design, but you might get lucky
hey fusion gurus, I have been messing around with models I downloaded from here, I want to assemble different models together but I can’t get the orientations right, plus positioning is difficult. I just want to attach trucks and wheels so I see how far back I need the handle part to stick out to be able make the bard stand on it.
BTW i don’t know if bending 1/4" aluminum is possible and won’t weaken it just
To bend aluminum without weakening, you have to anneal it first by heating it up to a certain temp, hold it for a set amount of time, and then let it air cool. Bend it when cool. Heat treat it again to bring it back to it’s strengthened state. Look up annealing aluminum and then look up T6 heat treatment. You’ll need a 1000°F /530°C oven. Bending aluminum in it’s hardened state will weaken it sadly. Good luck.
Thanks dude, seems like it is harder than I thought
Steel
you could weld a cool grip on too. like part of an old pipe wrench or something
Yeah might be the solution
Has anyone designed a 5 degree wedge for Matrix II trucks?
Since the baseplate has a footprint different from your typical skate trucks, I feel like risers and wedges should try to follow that shape, for more support/better look.
