stormcore100D casing v1.f3d (5.6 MB)
Thank you!
Looking for a model of the Elofty-like 58Kv DKP Direct Drive in .DWG, .IGS or .DGN.
Hints to anything similar like that appreciated!
So in my in-ability to leave well-enough alone, I decided that I did infact want to use the sensors on my motors but dont/didnt have a break away cable to ensure that if I want to drop the battery/esc’s from the board i can do so without a fuss.
Looking through my shelf of many things I came across my dupont connectors - decided that this could be something and jumped on thingverse. I found someone that made an OpenSCAD Parametric DuPont shell template, then found another guy that modified it to have multiple layers.
In our/my use case the polarity is quite specific and therefore i wanted to make sure it had some way to index in a way that would ensure it was never plugged in wrong.
So I modified the code as well to include an indexing shift that creates some beautiful asymmetry to make sure that the pins are consistent every time; It may be niche but if even one other person finds a use for it ill consider it 30 minutes well spent.
Smart BMS 12S.STEP (488.9 KB)
5065 motor
Infinity skinkindof.STEP (146.6 KB)
InfinitySink 2020 | Universal Heatsinks & Top Mount Boxes | BLACK FRIDAY SALE
design credits @surfnacho
M2.5 CLASS 12.9 SOCKET HEAD CAP SCREW.SLDPRT (398.0 KB) TB6 complete with screwirex.SLDASM (414.8 KB) TORQUERYBOX.SLDPRT (822.5 KB)
design credits @torqueboards
Any chance someone has the .stl of a Trampa hub or Trampa spoke
@Pedrodemio has a design that can be found here-
Thank you!
Dang, .step file
I can only Import .stl’s. Time for me to look around!
Here you go
SuperStars_Spoke.STL (223.6 KB)
If you need any other parts, lmk
@Pedrodemio did a phenomenal job labeling everything
THANK YOU!!
Haha thank Pedro. It was nothing thanks to his work
Time for you to download fusion😉
Touché
Keep mind that the triangular tip of the spokes is not perfect, for 3D printing adapter and all that it’s good, but do not mill anything for a aluminum or hard material since it will not fit. I never went back to fix it lol
