My first electric skateboard was an Evolve Bamboo of which it’s short coming gave me the idea of making the perfect board for myself and what I need to do to bring that board to reality.
First and fore most, very shit battery, need big pack and settled on 12s5p with the p side by side to keep the thickness thin. Reduce battery sag and increase range.
Second, board is a bit too small. It was comfortable but once my riding skill increased, some times for long rides, I would like to adjust my stance for whatever reason and the Evolve Bamboo board did not really allow that and the wheels would bite into the toe of my shoes.
Third, motors at the back is a no no, cannot stand the board up, motors under the deck is too close to the ground. Need the motors away in a way that I could still stand the board up, away from the road and safe from ledges, kerbs etc, also provide ease of adjusting belts if I need to.
Fourth, Pneumatics is nice but no thanks, do not want to deal with flats…Big thane wheels is where it is at for me, but too many have square edges, which would rail along uneven pavings if travelling almost parallel to it. Enter curved thanes from SR/Iwonder (Discovery version). Big enough and not square.
Fifth, drop down, I want bigger wheels but keep the board down. Evolve Bamboo is just drop through and the board did not go down that much really.
Sixth, Single hangers, not sidewinders and also need to find the perfect base plate angles for such a wide wheelbase. 38” is just the board itself, not the wheelbase
Seventh, Evolve Bamboo has thin as shit motor mounts and that was the first fail of the board, it broke and the belt got caught up in the wheel locking it and throwing me off, no problem as I have scaphoid protection plastic on my gloves and all I did was just simply slide till I came to a stand still. Seen many posts showing pics of broken mounts. It was only 3mm thick and of very low quality aluminium.
Eighth, fixed motor mounts, less things to check.
Ninth, fit in pulleys with it’s own bearing, I really liked that.
Tenth, hangers were too wide. I prefer to try and keep it more like normal long board so I had the hangers made as narrow as possible that could fit two enclosed MayTech 6355 motors with non adjustable motor mounts and it ended up being 211mm wide inside bearing to inside bearing.
First thing I had to look for is a board that will fit what I need in the list above and be able to house a 12s5p flat battery. I had a lot of trouble, it cannot be drop through and cannot be just a flat board with no concave. Another problem is how to have a board narrow enough at the ends to keep the hanger narrow and also allow the motors to sit above the board and still stay out of the way?? and a way to find what my perfect base plate angle is without having to buy all the base plates.
Solution was eventually found in SubSonic’s custom build page ( It is no longer on the website so I think they have stop offering custom made boards ) where they offer custom made boards of their normal board catalogues. I found that there is a board called the Illuminati which is designed to be used with G-Bomb brackets.
I had to look up G-Bomb brackets and viola, found the solution to the finding the perfect base plate angle problem and keeping the motors above and out of the way while still keeping the hangers as narrow as allowed by the dual motors!
Now, the standard Illuminati board was too short and narrow, no matter, had a custom one made at 38” long and 10” wide of which you now see in the photos!
Back then, I do not think anyone had any G-Bomb esk8. ( I do know that there is a girl here on the board that has one now ) which means I now need to make my own custom hangers, mounts and axles. So I had the Caliber Precision hangers and bolt on axle reverse engineered and then made changes to the design and gave the step files to the public for free to use as templates to design from or as is. Now that I had the custom designed hangers in step file, I could then made custom motor mounts. I had to made it more than paper thin and make some ramps for the phase wires to be eased down toward the hangers. Some mounts just simply force the phase wires almost 90 degrees down.
Once that is all done and a few errors later, all was done, then I made a single hanger/mount piece which is not quite done yet but will do for those who use screw on pulleys though.
I wanted a good quality job done for the enclosure so it looked like a boutique made board rather than a DIY and decided to go the CNC route and to keep it clean looking, opted for heat inserts like evolve and have the screw heads covered with grip tape which means I need to go ABS as the material. I would have designed the enclosure with one of the poster’s shop which had heat sinks for two VESC 6 MKII’s for a nicely more professional look rather than just eight ugly screws at the bottom of the board but the enclosure has already been made when I discovered the custom heat sink. Maybe another time…
Yeah it is built from the ground up with exactly what I wanted in mind, once I find the perfect base plate angle combo, I will have these made and set the G-Bomb bracket angles to 0 and slap these two on!
